嗨,希望通过HP3458A数字化1 kHz(1 Vpp)正弦波,并将采样数据传输到主机pc。我已经下载了示例程序,4100点程序,在c#中。
我可以让程序运行,创建样本并返回数据。它使用DCV数字化模式。现在,我想优化设置,使其特定于1kHz正弦波。示例测试程序代码:cmds =“PRESET DIG; “; //预设到指定状态(数字化)cmds + =“MFORMAT DINT;”; //设置内存存储格式(双整数)cmds + =“OFORMAT ASCII;”; //设置输出格式(ASCII)cmds + =“MEM FIFO;”; //清除内存并设置内存存储类型cmds + =“APER 2E-6;”; //设置arperature时间(cmds + =“TRIG AUTO;”; //设置触发源(Auto)cmds + =“NRDGS 4100,AUTO;”; //设置读数(4100读数)cmds + = “END ON;”; //启用EOI功能cmds + =“TARM HOLD”; //保持触发直到触发SendCmd(“TARM SGL”);我的程序,试图将1kHz正弦数字化:cmds =“PRESET DIG; “; cmds + =”MFORMAT DINT;“; cmds + =”OFORMAT ASCII;“; cmds + =”MEM FIFO;“; cmds + =”APER 0.0000122;“; cmds + =”tiMER 0.0000122;“; cmds + = “NRDGS 2048,TIMER;”; cmds + =“END ON;”; cmds + =“TARM HOLD”; SendCmd(“TARM SGL”);返回TARM SGL。2048(0到2047)样本的程序错误 然而,最后两个样本都没有了。当我完成一个FFT时,基本位于bin 51.通过上述设置,我希望这是1kHz,而bin #25的基波是我的采样数据。 相信我的设置应该代表这个数字化样本集:F0 = 1000.576 HzM = 25 CyclesN = 2048 SmplsFs = 81967.21311 HzFres = 40.023 HzI刚刚关闭 1kHz使Timer和Arp值保持100 nS的倍数。对于什么是错误的任何想法。 以上来自于谷歌翻译 以下为原文 Hi, Looking to digitize a 1 kHz (1 Vpp) sine wave via the HP3458A, and transfer the sampled data to the host pc. I've downloaded the example program, 4100 point program, in c#. I can get the program to function, create samples and return data. It uses the DCV digitizing mode. Now, i'd like to optimize the settings so it's specific to a 1kHz sinewave. Example test program code: cmds = "PRESET DIG;"; // Preset to the designated state (Digitizing) cmds += "MFORMAT DINT;"; // Set the memory storage format (double integer) cmds += "OFORMAT ASCII;"; // Set the output format (ASCII) cmds += "MEM FIFO;"; // Clear memory and set memory storage type cmds += "APER 2E-6;"; // Set the arperature time ( cmds += "TRIG AUTO;"; // Set the trigger source (Auto) cmds += "NRDGS 4100,AUTO;"; // Set the number of readings (4100 readings) cmds += "END ON;"; // Enable EOI function cmds += "TARM HOLD"; // Hold the trigger until triggered SendCmd("TARM SGL"); My Program, trying to digitize a 1kHz sine: cmds = "PRESET DIG;"; cmds += "MFORMAT DINT;"; cmds += "OFORMAT ASCII;"; cmds += "MEM FIFO;"; cmds += "APER 0.0000122;"; cmds += "TIMER 0.0000122;"; cmds += "NRDGS 2048,TIMER;"; cmds += "END ON;"; cmds += "TARM HOLD"; SendCmd("TARM SGL"); My program errors duing the TARM SGL. 2048 (0 to 2047) samples are returned, however the last two samples are out of wack. When I complete an FFT, the fundamental is at bin 51. With the above setting, i expect this to be 1kHz and a fundamental at bin# 25. Attached is my sampled data. I believe my setting should represent this digitizing sample set: F0 = 1000.576 Hz M = 25 Cycles N = 2048 Smpls Fs = 81967.21311 Hz Fres = 40.023 Hz I chose just off 1kHz to keep the Timer and Arp value a multipal of 100 nS. Any ideas as to what's wrong. |
5个回答
我玩弄了这个,发现你错过了TRIG AUTO命令,并且我得到了一个“触发太快”的错误,除非我放慢了计时器的速度。
请参阅下面的我的更改。我没有进行FFT,但我输入了一个2 Vpp 1 kHz正弦波,具有-1 V偏移,数据看起来很好。我编程,试图将1kHz正弦数字化:cmds =“PRESET DIG ;“; cmds + =“MFORMAT DINT;”; cmds + =“OFORMAT ASCII;”; cmds + =“MEM FIFO;”; cmds + =“APER 0.0000122;”; “TRIG AUTO”“TIMER 0.00003”cmds + =“NRDGS 2048,TIMER;”; cmds + =“END ON;”; cmds + =“TARM HOLD”; SendCmd(“TARM SGL”); 以上来自于谷歌翻译 以下为原文 I played around with this and found that you were missing the TRIG AUTO command and that I got a “trigger too fast” error unless I slowed down the timer. See my changes below. I didn’t do an FFT, but I input a 2 Vpp 1 kHz sine wave with a -1 V offset and the data looks good. My Program, trying to digitize a 1kHz sine: cmds = "PRESET DIG;"; cmds += "MFORMAT DINT;"; cmds += "OFORMAT ASCII;"; cmds += "MEM FIFO;"; cmds += "APER 0.0000122;"; “TRIG AUTO” “TIMER 0.00003” cmds += "NRDGS 2048,TIMER;"; cmds += "END ON;"; cmds += "TARM HOLD"; SendCmd("TARM SGL"); |
谢谢你的快速回复。哦,你的两个更新修复了我得到的错误。但我现在正在努力解决Aperture时间,样本数量和TIMER时间的关联。我的理解:孔径时间= 1 /采样率= 0.0000122
秒秒Fs = SamplingRate = 1 / TIMER = 81967.2131147539 Hz N =采样数= 2048光圈和TIMER时间只能以100 nS的增量进行更改,然后略微偏离1kHz的音调。 如果采样率高于以上且输入音调为Fo = 1000.576 Hz,(Fs / N = Fo / M),则预期M = 25个周期。 捕获的数据有比这更多的周期。 知道了,在FFT之后,我希望基波在bin#25中,因为Fres将是40.023 Hz。你可以帮助我将孔径时间,TIMER时间和样本数量等于拟合相干采样方程(Fs / N = Fo / M)。 我知道我不会连贯,因为3458与我的源不同步,但涂抹的基础应该散布在正确的bin中。 一个窗口稍后会帮助我。欣赏你的时间! 附上新的正弦数据。 以上来自于谷歌翻译 以下为原文 Thanks for the quick reply. Ok, your two updates fix's the error's I was getting. But I am now struggling with the association of the Aperture time, Number of Samples and TIMER time. My understanding: Aperture time = 1/Sample Rate = 0.0000122 Seconds Fs = SamplingRate = 1/TIMER = 81967.2131147539 Hz N = Number Of Samples = 2048 Aperture and TIMER time can only be changed in 100 nS increments, hece the slightly off 1kHz tone. With a SamplingRate of Above and Input tone of Fo = 1000.576 Hz, (Fs / N = Fo / M) i would expect M = 25 cycles. Data captured has many more cycles than that. Knowing that, post FFT, i would expect the fundamental to be in bin# 25 as the Fres would be 40.023 Hz. Can you help me equate aperture time, TIMER time and number of samples to fit the Coherent sampling equation (Fs / N = Fo / M). I know I will not be coherent as the 3458 is not synchronized to my source, but the smeared fundamental should be spread around the correct bin. A window will later help me out there. Appreciate your time! Attached new sine data. 附件
至少部分答案是3458A具有集成A / D而不是像示波器那样的闪存A / D.
光圈时间是A / D对输入信号进行积分的实际时间。 采样率是触发A / D时的速率,这是= 1 / TIMER。 触发和测量开始之间可能存在延迟,以便在必要时进行稳定。 请参阅3458A用户指南的第160页:指定值FYIIf如果需要超过50KHz,则必须使用MFORMAT SINT和OFORMAT SINT 以上来自于谷歌翻译 以下为原文 At least part of the answer is that the 3458A has an integrating A/D not a flash A/D like a scope. Aperture time is the actual time the A/D is integrating the input signal. The sample rate is the rate at with the A/D is triggered and this does = 1/TIMER. There can be a delay between the trigger and the measurement start to allow settling if necessary. See page 160 of the 3458A User’s Guide: Specifying a value <500ns selects minimum aperture which is 500ns. FYI If you need to go faster than 50KHz you must use MFORMAT SINT and OFORMAT SINT |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1422浏览 1评论
827浏览 0评论
1192浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 06:04 , Processed in 1.383109 second(s), Total 83, Slave 67 queries .
