嗨,我从第一个版本开始使用MPLAB X,我非常喜欢。自从第一个版本以来,有一些与文件之间的可视化和链接相关的bug,但是对于最新的版本(3.30-3.35),情况比以往任何时候都糟糕……所以我决定写在这里,也许只是我的问题,有人可以帮我……第一件事是文本颜色。当我打开MPLAB X和项目时,看起来不错,但是当我开始修改它时,颜色不符合规则…(灰色的代码,比如if是注释,红色下划的代码,比如if是某些错误等等)第二件事发生在交换包含相同库的项目时。新项目中的链接继续沿袭以前的项目路径……我是唯一一个有这个问题的人?谢谢
以上来自于百度翻译 以下为原文 hi, i'm using MPLAB X since the first version and i like it very much. since the first release there was somef bugs related to the visualization and link between files but with the latest versions (3.30 - 3.35) the situation is worst then ever... so i decide to write here, maybe is only my problem and someone can help me... the first thing is the text color. it seems ok when i open MPLAB X and the project but when i start to modifie it the colour does not follow the rules.... (code in gray like if were comment, code underlined in red like if were some errors and so on). the second thing occur when swap through project that include same libraries.. the link in the new project continue to follow the previous project paths.. i'm the only one with this issues? thanks |
对。。只是一些错误..首先…EEPROFSIZE是错误的。我在PIC18F46K22上,当1024K生效时,EEADRH=_adr>>8行被编译,即使用灰色显示,程序也如预期的那样工作。线从28到32是彩色的,如果是有效的,但我在PIC18F2550不是12F1840…MPLAB X重启后全部显示正确
以上来自于百度翻译 以下为原文 yes.. just some errors.. first.. _EEPROMSIZE is wrong.. i'm on PIC18F46K22 that as 1024K infact the line EEADRH = _adr >> 8 is compiled even if is showed in grey and the program works as expected. second.. line from 28 to 32 is colored like if were valid but i'm on PIC18F2550 not 12F1840.. after MPLAB X restart all is showed properly Attached Image(s) |
是的,看起来好像有一些代码突出显示问题,我有一些代码在3.26以下突出显示得很好,但是在3.35中没有。_EEPROMSIZE只对NON PIC18设备有效。
以上来自于百度翻译 以下为原文 Yes, it looks as if there are some code highlighting issues, I have code that highlights fine under 3.26 but doesn't in 3.35. _EEPROMSIZE is only valid for NON PIC18 devices. |
5459 浏览 9 评论
2157 浏览 8 评论
2058 浏览 10 评论
3325 浏览 3 评论
2365 浏览 5 评论
963浏览 1评论
823浏览 1评论
820浏览 1评论
850浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
538浏览 0评论
GMT+8, 2025-4-28 14:59 , Processed in 1.438152 second(s), Total 75, Slave 59 queries .
