PSoC 3/5LP具有UBFS、UART、SPI和基于I2C的引导加载程序。
这里是一个基于组件的Bootloader。主机应用程序通信的Bootloader可以通过I2C。有u***to I2C桥坐在主人和引导主机。附件是canbootloader(I2C可以桥),bootloadable和详细的pdfexplaining实施。 问候,Sobi CANBooBooLoad和I2C-CAN桥接 5.3兆字节 以上来自于百度翻译 以下为原文 PSoC 3/5Lp has USBFS, UART, SPI and I2C based bootloaders . Here is a CAN Component Based Bootloader . The Host application communicate to the Bootloader CAN through I2C. There is a USB to I2C bridge sitting betwen the Host and Bootloader Host . Attached is the CAN Bootloader ( I2C to CAN bridge) , Bootloadable and a detailed PDF explaining the implementation. Regards, Sobi |
4个回答
你真的阅读了提供的档案中的文档吗?
以上来自于百度翻译 以下为原文 Did you actually read the documentation in the supplied archive? |
我把PC、MIUPROG、PSOC31001DVK作为PC机的一部分,发送直接CAN包,现在我做了Cig帧,我想在编程的基础上做出改变,可以接收和响应帧。
FraseSeNeX.xLSX 11.8 K 以上来自于百度翻译 以下为原文 I consider pc,miniprog,psoc3 001dvk as part of pc and sending direct can packet now i made cane frame and i want to make changes in programming according to this can frames receive and respond.how i can change in programming.plz peply as soon as possibal...thanks
夏威夷群岛
我是BeigelCAN Unrz解释我的Quutle与U.KnalaG.PLZ告诉我,我们需要什么样的改变框架可以如上所述。 以上来自于百度翻译 以下为原文 HI I am bignear can u plz explain above my quation with ur knolage.plz tell me what changes we need for can frames as explained above. |
嗨,大家好,
我可以在Bootloader上开发Bootloader吗?请修改我的代码,请告诉我需要更改哪些组件? 以上来自于百度翻译 以下为原文 HI all, Can i devlop CAN based bootloader by making changes in bellow attached code please tell me which components i need to change? |
762个成员聚集在这个小组
加入小组2181 浏览 1 评论
1928 浏览 1 评论
3749 浏览 1 评论
1851 浏览 6 评论
1596 浏览 1 评论
824浏览 2评论
638浏览 2评论
508浏览 2评论
472浏览 2评论
1341浏览 2评论
GMT+8, 2025-3-31 13:04 , Processed in 1.094861 second(s), Total 82, Slave 66 queries .
