是否有用于MEMS麦克风演示器的示例apc文件?如应用笔记所示:AP4146,例如基本定向麦克风设置。似乎没有可用的帮助或这些板的支持文档很少。
以上来自于谷歌翻译 以下为原文 Are there any example apc files for the MEMS microphone demonstrator? as indicated in the application note: AP4146, For example basic directional microphone set-up. There seems to be no Help available or very little supportive documentation for these boards. |
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00061574.pdf
包括有关http://www.st.com/web/en/catalog/tools/PF255176的所有相关信息 董事会使用。每个特定电路板也可以使用其他材料,例如http://www.st.com/memsmics 或http://www.st.com/web/en/catalog/tools/PF258331 接口。 配置文件(.apc)可以由用户创建,也可以由ST根据特定请求提供 - 如有需要,请联系ST代表。 以上来自于谷歌翻译 以下为原文 http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00061574.pdf includes all relevant information about the http://www.st.com/web/en/catalog/tools/PF255176 board usage. Additional material is also available for each specific board which could operate with it, such as http://www.st.com/memsmics or the http://www.st.com/web/en/catalog/tools/PF258331 interface. Configuration files (.apc) can be either created by the user or provided by ST upon specific request - contact an ST representative in case of need. |
2422 浏览 1 评论
3138 浏览 1 评论
1707 浏览 1 评论
3520 浏览 6 评论
5878 浏览 21 评论
862浏览 4评论
1238浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
506浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1220浏览 3评论
1274浏览 3评论
GMT+8, 2024-9-22 01:16 , Processed in 0.946929 second(s), Total 78, Slave 62 queries .
