任何博士都能说出Agilent 86100A Infiniium DCA时域反射仪的等效模型是什么。
实际上我想测量高达12Ghz的时域参数,所以请告诉我以下型号的等效型号是什么:86100A 86100A-ETR 86100A-202 54754A N1020A N1021B N1024B将9000系列示波器支持TDR测量? 如果是的话配置是什么。 以上来自于谷歌翻译 以下为原文 Can any boby say what is the equivalent model for Agilent 86100A Infiniium DCA time Domain Reflectometry. actually i want to measure the Time domain parameters up to 12Ghz, so please tell me what are the equivalent models for the given below model no: 86100A 86100A-ETR 86100A-202 54754A N1020A N1021B N1024B will 9000 series oscilloscope support TDR measurments ? if so what is the configuration. |
3个回答
您好,86100A已被86100B取代,然后是86100C,现在是86100D。
目前的配置如下:86100D DCA-X主机86100D-STR标准触发选项86100D-GPI GPIB接口86100D-202增强型阻抗和S参数软件54754A差分TDR模块N1021B差分TDR探头N1024B TDR校准套件TDR / TDT测量是 取样范围。 实时示波器(例如9000系列)没有TDR功能。 如果您认为有需要,或者您想讨论更多细节,请发给我私信。 此致,Joachim Vobis安捷伦科技,示波器产品部 以上来自于谷歌翻译 以下为原文 Hello, The 86100A has been replaced by the 86100B then 86100C and now 86100D. The current configuration would be this: 86100D DCA-X Mainframe 86100D-STR Standard trigger option 86100D-GPI GPIB Interface 86100D-202 Enhanced impedance and S-parameter software 54754A Differential TDR module N1021B Differential TDR Probe N1024B TDR calibration kit TDR/TDT measurements are made on sampling scopes. Real-time scopes, such as the 9000 series, don't have TDR capabilities. If you think there is a need for that, or if you like to discuss more details, then please send me a private message. Regards, Joachim Vobis Agilent Technologies, Oscilloscope Products Division |
zajxldy 发表于 2019-7-24 10:55 谢谢你的回复Mr.Joachim Vobis 以上来自于谷歌翻译 以下为原文 Thanks for your reply Mr.Joachim Vobis |
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1111浏览 1评论
753浏览 0评论
926浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-24 01:46 , Processed in 1.411337 second(s), Total 82, Slave 66 queries .
