大家好,我用CY7C68013A芯片访问USB端口。
在附属物中的示意图是: 现在我把一个USB插入到PC机中,PC在“设备管理”中找到新设备,但也不能识别它。 我已经安装了这个芯片的驱动程序,但是PC仍然找不到这个设备, 它测量电压,我确信复位/唤醒是高的,唤醒是低的。 我怎样才能解决这个问题,你能帮我一些忙吗? 谢谢你 ??PNG 36.6 K 以上来自于百度翻译 以下为原文 Hello, everyone, i am using the chip cy7c68013a to access an u*** port. The schematic is as belows in the attachment: and now i plug a u*** into the pc, the pc find new device in the "device manage" , but could nor recognize it. and i have installed the driver for this chip, but the pc still could not find the device, it have measure the voltage ,and i am sure that the reset/wake up is high and the wake up is low How could i solve the problem, could you give me some help? Thank you
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1575 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-25 09:33 , Processed in 1.017126 second(s), Total 74, Slave 58 queries .
