大家好
我想使用多DMAS并行,而不是使用第一个DMA来请求下一个DMA。例如,我使用自定义触发器组件逐个请求DMAS。我假设每个DMA组件可以单独工作并并行运行,从而可以加速总DMA速度。这正是我所期待和设想的,有人能告诉我这是否可行?或者有另一种方法可以加快DMA。 谢谢 以上来自于百度翻译 以下为原文 Hi all I want to use multi DMAs by parallel rather than using first DMA to request next DMA. For example, I use a custom trigger component to request DMAs one by one. I assume that each DMA component can work individually and run as parallel, so that total DMA speed can be accelerated. It is just what I expect and assume, could any one tell me this is available or not?? Or there is an another way which can speed up DMA. Thanks |
简而言之,在不同的DMA信道之间并行运行。
由于你没有详细说明你所遇到的问题,所以很难给你提建议。 但要确保:运行数据传输的单个大坝通道总是比执行同一共享作业的多个通道快。 鲍勃 以上来自于百度翻译 以下为原文 In short: There is a priorization between the different DMA-channels running in parallel. Since you do not specify much about the problem you have got it is difficult to give you advise. But be sure: a single DAM channel running to transfer data will always be faster than multiple channels performing the same shared job Bob |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 12:55 , Processed in 0.742474 second(s), Total 47, Slave 41 queries .
