我将可变长度从9位更改为32位,系统未通过测试。
我不确定为什么更改导致失败,因为逻辑方面它不应该影响测试结果(因为frame_sync_width没有在任何地方处理,逻辑应该被更改。这个更改是否导致任何时序更改?)。 以下是我对每个文件所做的更改。 registers.v: old:output [8:0] dpll_clk_count; reg [8:0] dpll_clk_count; dpll_clk_count `DPLL_CLK_COUNT_REGISTER:dpll_clk_count usrt.v: 旧: wire [8:0] dpll_clk_count; dpll dpll_c(.rx_clk_out(dpll_rx_clk),. tx_clk_out(dpll_tx_clk),. dplla(dplla),. rx_data(rx_data),. enable_dpll(rx_clk_dpll),. enable_phase_shift(enable_phase_shift),. fm_mode(fm_mode),. manchester_mode(manchester_mode) ,.dpll_clk_count(dpll_clk_count),. redset(reset),. clk(bgr_clk_out)); 新: wire [31:0] dpll_clk_count; wire [5:0] frame_sync_width; assign frame_sync_width = colin_en? dpll_clk_count [31:26]:'bz; dpll dpll_c(.rx_clk_out(dpll_rx_clk),. tx_clk_out(dpll_tx_clk),. dplla(dplla),. rx_data(rx_data),. enable_dpll(rx_clk_dpll),. enable_phase_shift(enable_phase_shift),. fm_mode(fm_mode),. manchester_mode(manchester_mode) ,.dpll_clk_count(dpll_clk_count [8:0]),. redset(reset),. clk(bgr_clk_out)); registers.v文件用作usrt.v中的模块。 *论坛管理员删除了附件 以上来自于谷歌翻译 以下为原文 I changed the variable length from 9 bits to 32 bits and the system failed the test. I am not sure why the change causes the failure because logic-wise it shouldn't affect the test result (since the frame_sync_width is not being handled anywhere, the logic should be changed. Is this change cause any timing change? ). The following is the changes I have made on each file. registers.v: old: output [8:0] dpll_clk_count; reg [8:0] dpll_clk_count; dpll_clk_count <= 8'b00000100;//default to 32 clocks `DPLL_CLK_COUNT_REGISTER : dpll_clk_count <= cpu_wr_data[8:0]; `DPLL_CLK_COUNT_REGISTER : reg_data = {23'b0,dpll_clk_count}; new: output [31:0] dpll_clk_count; reg [31:0] dpll_clk_count; dpll_clk_count <= 32'h4;//default to 32 clocks `DPLL_CLK_COUNT_REGISTER : dpll_clk_count <= cpu_wr_data; `DPLL_CLK_COUNT_REGISTER : reg_data = dpll_clk_count; usrt.v: old: wire [8:0] dpll_clk_count; dpll dpll_c ( .rx_clk_out(dpll_rx_clk), .tx_clk_out(dpll_tx_clk), .dplla(dplla), .rx_data(rx_data), .enable_dpll(rx_clk_dpll), .enable_phase_shift(enable_phase_shift), .fm_mode(fm_mode), .manchester_mode(manchester_mode), .dpll_clk_count(dpll_clk_count), .reset(reset), .clk(bgr_clk_out) ); new: wire [31:0] dpll_clk_count; wire [5:0] frame_sync_width; assign frame_sync_width = colin_en ? dpll_clk_count[31:26] : 'bz; dpll dpll_c ( .rx_clk_out(dpll_rx_clk), .tx_clk_out(dpll_tx_clk), .dplla(dplla), .rx_data(rx_data), .enable_dpll(rx_clk_dpll), .enable_phase_shift(enable_phase_shift), .fm_mode(fm_mode), .manchester_mode(manchester_mode), .dpll_clk_count(dpll_clk_count[8:0]), .reset(reset), .clk(bgr_clk_out) ); The registers.v file is used as a module in usrt.v. *attachments removed by Forums admin |
我建议你做路线后模拟,看看变化后的行为是否符合预期。如果你没有在模拟中看到正确的行为,那么工具可以进行一些优化.Regards,Krishna
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 I would recommend you to do post-route simulations to see if the behavior after the change is as expected. If you are not seeing the correct behavior in the simulation then there could be some optimization done by the tool. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
可能存在修整或不正确的逻辑合成。
请检查合成和地图重新编辑是否有任何修剪逻辑。 如前所述,路线后模拟肯定会追踪失败点。 希望这可以帮助。 问候 Sikta 以上来自于谷歌翻译 以下为原文 There could be trimming or incorrect logic synthesiszed. Please check the synthesis and map reprots for any trimming logic. As suggested earlier, post route simulations definitely track down the failure points. Hope this helps. Regards Sikta |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2474 浏览 15 评论
1478浏览 1评论
601浏览 1评论
467浏览 1评论
2018浏览 0评论
741浏览 0评论
GMT+8, 2025-1-1 23:41 , Processed in 1.275993 second(s), Total 80, Slave 64 queries .
