亲爱的支持团队,
我按照数据表的建议使用TDA7293。我也在使用MUTE和STBY引脚,但不使用CLIP-DET引脚。一切都在没有任何问题。 我的问题是: 1.我可以使用1N4148二极管将TDA7293上的CLIP-DET引脚连接到MUTE引脚,使阳极连接到MUTE引脚,阴极连接CLIP-DET引脚吗?我的想法是在放大器剪辑时静音。 2.启动期间TDA7293是否对STBY引脚上的电压敏感? STBY引脚上的电压是否有任何条件(例如OPEN),以至于在这种情况下IC可能会损坏或只是爆炸? 互联网上有一些关于TDA7293被炸毁的线索。这可能发生的具体条件是什么? 4.我可以将TDA7293用作非inv V-I转换器,使扬声器和电流检测电阻成为增益电阻吗? 提前致谢!! 温暖的问候, 拉温德拉。 以上来自于谷歌翻译 以下为原文 Dear Support Team, I am using the TDA7293 as per datasheet recommendations. I am also using the MUTE and STBY pins but not the CLIP-DET pin. Everything is working without any issues. My question is: 1. Can I connect the CLIP-DET pin on TDA7293 to the MUTE pin using a 1N4148 diode such that the anode connects to the MUTE pin and the cathode connects the CLIP-DET pin? My idea is to mute the amplifier whenever it clips. 2. Is the TDA7293 sensitive about the voltage on STBY pin during start-up? Is there any condition around the voltage on STBY pin (e.g. OPEN) such that under that condition the IC can get damaged or just blow-up? 3. There are some threads around on the internet about the TDA7293 getting blown-up. What are the specific conditions under which this can happen? 4. Can I use the TDA7293 as a non-inv V-I converter such that the loudspeaker and the current sense resistors become the gain resistors? Thanks in advance!! With wARM regards, Ravindra. |
2895 浏览 1 评论
3283 浏览 1 评论
1864 浏览 1 评论
3715 浏览 6 评论
6130 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
414浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
514浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
339浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
247浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
356浏览 2评论
GMT+8, 2025-3-5 04:48 , Processed in 1.146560 second(s), Total 39, Slave 34 queries .
