你好
我使用NFC内存m24sr64和专用源代码('STM32CubeExpansion_NFC1_V1.6.0')。 我有一个使用i2c令牌释放序列的问题,应该关闭i2c会话。 事实上,我们的micro发送开始条件和从属地址,但是,然后,ms24sr将SCL线路阻塞到低电平28ms,然后再释放它。 然后发生停止条件。 因此,在i2c令牌释放序列期间,我们的micro发送8个时钟周期用于开始和从属地址,第9个出现在28ms之后。 因此,与m24sr64数据表上的序列相比,令牌释放序列似乎不正确。 您是否知道为什么m24sr64应该在令牌释放序列期间阻止SCL线,尽管我们发送了正确的地址? 谢谢 ! 以上来自于谷歌翻译 以下为原文 hello i use the nfc memory m24sr64 with the dedicated source code ('STM32CubeExpansion_NFC1_V1.6.0'). I have an issue using the i2c token release sequence, supposed to close the i2c session. In fact, our micro sends the start condition and the slave adress, but then, the ms24sr blocks the SCL line to low level for 28ms before releasing it. Then the stop condition occurs. So, during the i2c token release sequence, our micro sends 8 clock period for the start and the slave adress, and the 9th appears 28ms later. So, the token release sequence seems not being correct, compared to the sequence on the m24sr64 datasheet. Do you have an idea why the m24sr64 should block the SCL line during the token release sequence, although we send its correct adress ? thank you ! |
你好Catheline,
通常,I2C令牌释放应该将SCL线路置于BSP驱动器中40ms的低电平。为此,它使用基于HAL Systick计时器的HAL_Delay函数。您是否修改了Systick的TimeBase,它应设置为1ms。 最好的祝福。 以上来自于谷歌翻译 以下为原文 Hi Catheline, Normally the I2C Token release is supposed to put the SCL line Low for 40ms in the BSP driver. For that it uses the HAL_Delay function based on the HAL Systick timer. Did you modify the TimeBase of the Systick, it should be set to 1ms. Best Regards. |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 10:36 , Processed in 1.120694 second(s), Total 77, Slave 61 queries .
