大家好,
如果我的问题对于这个论坛来说太基本了,我很抱歉,但我一直在互联网上阅读这么多来源,我仍然很困惑,我在这个主题上几乎是新的。 我希望通过使用范围在20 kHz和200 kHz之间的模拟mems麦克风来听到超声波。我有几种不同类型的mems模拟麦克风( SPU0410HR5H?PB,SPU0410LR5H-QB,ICS-40180)和驻极体(CMA-4544PF-W)。我知道范围超出了这些麦克风的听觉范围,但我读到它可以完成。有人可以分享一些想法如何做到这一点? 感谢您的关注 吉娜 #ultrasound #mems-microphone 以上来自于谷歌翻译 以下为原文 Hello everyone, I apologize if my question is too basic for this forum but i've been reading so many sources in the internet and i am still confused and I am pretty much new in this subject. I want to hear ultrasound by using analog mems microphone between range 20 kHz and 200kHz. I have several different types of mems analog microphone ( SPU0410HR5H?PB, SPU0410LR5H-QB, ICS-40180) and electret (CMA-4544PF-W). I know that the range is out of the hearing range of these microphones, however i read that it could be done. Could someone please share some idea how to do this ? Thank you for your attention Gina #ultrasound #mems-microphone |
4个回答
我读到它可以做到你在哪里读到的?你有没有联系谁写过它?
为什么不使用专门为此目的设计的传感器? 以上来自于谷歌翻译 以下为原文 i read that it could be doneWhere did you read that? Have you contacted whoever wrote it? Why not just use a transducer specifically designed for this purpose? |
http://www.lmgtfy.com?q=ultrasonic+MEMS+Microphone
以上来自于谷歌翻译 以下为原文 http://www.lmgtfy.com?q=ultrasonic+MEMS+Microphone |
麦克风不能用于超声的原因是因为麦克风在空气中工作而超声波在水中工作。
密度差异很大,完全是784x。 通过水发出的声音在空气中传播不好, 麦克风是沉默的。 通常许多超声波接收器安装在同一发射头内,嵌入与身体类似的液体密度。 以上来自于谷歌翻译 以下为原文 The reason microphones wont work for ultra sound is because microphones work in air and ultrasound works in water. the difference in density is huge, 784x exactly. sounds sent through water don't transmit well in air, the microphones are silent. usually many ultrasonic receivers are mounted within the same transmit head, embedded in a similar liquid density as the body. |
2983 浏览 1 评论
3311 浏览 1 评论
1891 浏览 1 评论
3744 浏览 6 评论
6159 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
53浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
54浏览 5评论
89浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
53浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
52浏览 5评论
GMT+8, 2025-4-1 14:32 , Processed in 1.008734 second(s), Total 84, Slave 66 queries .
