您好,我刚刚买了PIC 32 MZ2048 EFH,并下载了Altic库来创建一个PCB。然而,这里没有列出这个集成电路,但是还有一个是图32MZ2048ECM144T-I/PH。我比较了我的集成电路(32MZ2048EFH)的引脚,并注意到它们都是一样的,在尺寸方面也是类似的。有人知道脚印是否兼容?干杯
以上来自于百度翻译 以下为原文 Hello, I just bought the pic 32MZ2048EFH, and downloaded the altium library to create a pcb. However this IC is not listed there but there is another one which is the pic 32MZ2048ECM144T-I/PH. I compared the pin outs of my IC (32MZ2048EFH) and noticed that they were all the same, similarly for the dimensions. Does anybody know if the footprint is compatible ? Cheers |
4个回答
是的,脚印是兼容的。两者之间的唯一区别是严格的内部。ECM有一个密码引擎,EFH有一个FPU。
以上来自于百度翻译 以下为原文 Yes, the footprints are compatible. The only difference between the two is strictly internal. The ECM has a crypto engine, and the EFH has a FPU. |
Las,在高空创建新的足迹非常容易,如果您不那么热衷于输入100个引脚的数据,也可以导入一个引脚列表。
以上来自于百度翻译 以下为原文 Las, its pretty easy to create new footprints in altium and you can import a pin list as well, if you are not so keen on entering data for 100 pins. |
PIN列表只是一个包含PIN或其他特殊类型文件名称的文本文件吗?谢谢你的回复:
以上来自于百度翻译 以下为原文 Is the pin list just a text file containing the names of the pins or some other special type of file? thanks for the replies :) |
PIN列表只需要是CSV类型的文件。Alitum会让你操纵它。V= 0N6K6GYYIV0
以上来自于百度翻译 以下为原文 the pin list just needs to be a CSV type file.. Alitum will let you manipulate it somewhat. https://www.youtube.com/watch?v=0n6k6GYu_V0 |
5344 浏览 9 评论
2085 浏览 8 评论
1989 浏览 10 评论
3265 浏览 3 评论
2302 浏览 5 评论
847浏览 1评论
742浏览 1评论
685浏览 1评论
741浏览 0评论
632浏览 0评论
GMT+8, 2025-2-14 05:40 , Processed in 1.042484 second(s), Total 50, Slave 44 queries .
