大家好,我正在尝试使用DRVII2C动态实例。但是我有足够的……i2c总线上的一些设备需要延迟时间来纠正行为。因此我需要在writeThenRead函数之间插入时间延迟。我期望以下顺序:Start->address->write->start->read->read->
以上来自于百度翻译 以下为原文 Hello all. I am trying force using DRV_I2C dynamic instance. but i have enough.... Some device on i2c bus, required delay time, to correct behavior. So I need insert time delay between writeThenRead function. i expect following sequence: Start->address->write (delay) start->read->read->read->read->stop any idea how to implement using DRV_i2C ? |
3个回答
使用static并编辑代码。static将代码副本放在StasyCyFig文件夹中。
以上来自于百度翻译 以下为原文 Use Static and edit the code. Static puts a copy of the code in the system_config folder. |
谢谢你的回答,我知道,我可以修改源代码…或者使用低级PLIB库…但是对于什么是高级API,这是完全不可用的。另外在新的和声中有一些关于静态库API的描述,被删除了……(只有靠帮助才是幸运的)
以上来自于百度翻译 以下为原文 thanks for answer, i know that, i can modify source code.... or using low level PLIB library... But for what are high level API, this completely unusable. Additional in new harmony some description about static library API, was removed...... (fortunate only from help) |
你可以试用一张支持票,但它们可能很慢。如果有的话,联系你的F.A.E。你可以忽略Harmony Code,用或不用PBLib编写你自己的驱动程序。我不建议编辑HarmonyLib代码。在每次新的和声更新之后,你必须重新合并你的修改。你需要弄清楚什么会对你的日程安排起作用。
以上来自于百度翻译 以下为原文 You can try a support ticket, But they can be slow. contact your F.A.E., if you have one. You can ignore the Harmony Code and write your own driver with or without the PBLib. I would not recommend editing the Harmony Library code. You will have to re-merge your changes after each new harmony update. You will need to figure out what will work for your schedule. |
5368 浏览 9 评论
2100 浏览 8 评论
2004 浏览 10 评论
3277 浏览 3 评论
2312 浏览 5 评论
879浏览 1评论
767浏览 1评论
706浏览 1评论
764浏览 0评论
653浏览 0评论
GMT+8, 2025-3-6 02:24 , Processed in 1.305476 second(s), Total 80, Slave 64 queries .
