你好,
我想订购一个样品来尝试建立一个自己的蓝牙盒子。在我发送请求后,它会显示您的订单已成功创建,但我无法在订单历史记录中看到它。关闭选项卡后,它会再次显示图表中的项目。 以上来自于谷歌翻译 以下为原文 Hi at all, I wanted to order a sample product to try to build up a own bluetooth box. After I send my request, it shows your order has succesfully created but I can't see it in the order history. After I close the tab, it shows the items in the chart again. |
11个回答
嗨亚历山大
是否有您指的特定产品?请查看本页顶部的论坛列表,告诉我这里适用的选项。 谢谢 奥利 以上来自于谷歌翻译 以下为原文 Hi Alexander Is there a particular product you are referring to? Take a look at the Forums list at the top of this page and let me know which option applies here. Thanks Oli |
嗨奥利,
谢谢你的快速回复。这是模拟和音频论坛。我没有看到不同的论坛。抱歉。我找了TDA749213TR。我也试过了 TDA7294HS 和TDA7294V作为测试,结果相同。没有错误消息,但内容未显示在订单历史记录中。 非常感谢, 亚历克斯 以上来自于谷歌翻译 以下为原文 Hi Oli, thank you for this fast reply. It's the analog and audio forum. I didn't see the different forums. Sorry. I looked for the TDA749213TR. I also tried the TDA7294HS and TDA7294V as a test, with the same result. There is no error message but the content does not appear in the order history. Thanks a lot, Alex |
嗨Alexander,
我有一个类似的问题。我们想订购一些样品,以便在STM32L4的基础上开发一些CAN传感器 但是,一旦我可以订购样品,在您的情况下,我的购物车中没有任何东西。 当我第二次尝试下订单时出现错误 'Oups,出了点问题。请稍后再试' 另外对我来说,目前无法进行样品订购。 谢谢,蒂莫 以上来自于谷歌翻译 以下为原文 Hi Alexander, I have a similar problem. We wanted to order few samples to develop some CAN sensors on base of the STM32L4 However, once I could order the samples and like in your case nothing was in my cart. When I try to do the order a second time there comes an error 'Oups, something went wrong. Please try again later' Also for me Sample ordering is not possible at the moment. Thanks, Timo |
你好
meyer.timo 和H_rtel.Alexander “感谢您的反馈,我已在内部报告了样品订购问题。 关于您的具体样品订单,我强烈建议您在此处发送请求: https://my.st.com/content/my_st_com/en/my-space/my-onlinesupport.html 它将由我们的客户支持团队处理 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi meyer.timo and H_rtel.Alexander ‌Thanks for your feedback, I've reported the sample ordering issue internally. Regarding your specific samples order, I highly recommend you to send a request here: https://my.st.com/content/my_st_com/en/my-space/my-onlinesupport.html and it will be processed by our Customer Support team Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
订购样品时遇到了同样的问题 - 我已经把LPS25HBTR和LSM303CTR放到了篮子里并完成了表格。单击“提交”后,表单显示一切正常,但订单未放入历史记录,并且(正如我所知)未继续。我在不同的操作系统和计算机上尝试过几次但没有进展......
那一定是订单系统,请你检查一下发生了什么? 以上来自于谷歌翻译 以下为原文 I've got the same problem with ordering the samples - I've put to the basket the LPS25HBTR and LSM303CTR and fulfilled the form. After clicking 'submit' the form saied that all is ok but the order was not put to the history and is (as I know) not proceeded. I've tryed several times on different OS and computers but without progress... That must be sth with the order system, could You please check what's going on? |
我的问题是,国家号码已被添加,但我也在我的phne nukber中添加了0。当我更新我的个人资料时,提到了这个问题。
以上来自于谷歌翻译 以下为原文 My problem was, that the country number was added, but I also added a 0 to my phne nukber. The problem was mentioned when I updated my profile. |
你好
pyka.adam.001 “我也建议你和我上面提到的一样: 请在这里加票: /external-link.jspa?url=https%3A%2F%2Fmy.st.com%2Fcontent%2Fmy_st_com%2Fen%2Fmy-space%2Fmy-onlinesupport.html 它将由我们的客户支持团队处理 在不太可能的情况下,你没有得到你的机票的回复,请通过私人消息与你联系我ticket我将在内部检查 meyer.timo and和H_rtel.Alexander ④:这同样适用于您。如果您关于样品问题的机票无法解除阻止,请通过私信将您的机票发送给我,我会让同事查看。 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi pyka.adam.001 ‌I also suggest to you the same I've suggested above: please raise a ticket here: /external-link.jspa?url=https%3A%2F%2Fmy.st.com%2Fcontent%2Fmy_st_com%2Fen%2Fmy-space%2Fmy-onlinesupport.html and it will be processed by our Customer Support team In the unlikely case you don't get a reply to your ticket, please contact me via private message with your ticket ♯ and I'll check internally meyer.timo ‌ and H_rtel.Alexander ‌ : the same applies to you. In case your ticket regarding the samples issue didn't manage to unblock the situation, please send me your ticket ♯ via private message and I'll have a colleague look into that. Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
你好
H_rtel.Alexander “问题现在已经解决,您是否可以订购样品? 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi H_rtel.Alexander ‌so the problem is now solved and you were able to order the samples or not? Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
你好
meyer.timo “您是否能够订购样品或仍然遇到同样的问题? 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi meyer.timo ‌Have you been able to order the samples or still experience the same issue? Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
我遇到的问题与人们在本主题中遇到的问题相同。我已经发送了支持请求,我得到了一个标准答案,其中包含有关样本请求过程的指导。有人可以在这种情况下提出建议吗?
以上来自于谷歌翻译 以下为原文 I have the same problem as people have in this topic. I have sent request to support and i got a standard answer with an instructiction about process of request of samples. Could someone to advice something in this case? |
你好
shpileuski12 确保,私下给我留言,我将能够帮助你 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi shpileuski12 ‌sure, drop me a message in private and I will be able to help you Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2775 浏览 1 评论
3251 浏览 1 评论
1822 浏览 1 评论
3666 浏览 6 评论
6060 浏览 21 评论
1347浏览 4评论
212浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
367浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
463浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
291浏览 2评论
GMT+8, 2025-1-8 07:25 , Processed in 1.299777 second(s), Total 98, Slave 82 queries .
