我下载了代码配置器,但是zip文件包含一个NETBEN文件,我不能打开它来安装配置器。
以上来自于百度翻译 以下为原文 I downloaded the Code Configurator however the Zip file contains a Netbean file which I can't open to install the Configurator. Any suggestions, Regards, Russell |
HI罗素,ZIP文件包含一个NBM文件,它是MPLABX使用的标准NETBeBeIDE插件格式。您需要在MPLABX中安装这个nbm文件,方法是转到Tools菜单-->Plugins-->Downloaded-->Add Plugins-->从zip归档文件中选择nbm文件-->Install&Restart MPLABX。插件服务器:选择“工具”菜单,然后点击“插件”在MPLLABXIDE插件窗口,点击“可用插件”选项卡选择MPLAB代码配置器,然后点击“安装”。
以上来自于百度翻译 以下为原文 Hi Russell, The zip file contains an nbm file, which is the standard Netbeans IDE plugin format which MPLABX uses. You need to install this nbm file in MPLABX by going to the Tools menu --> Plugins --> Downloaded --> Add Plugins --> Select the nbm file from the zip archive --> Install & Restart MPLABX. Alternatively, if you just want the latest MCC version, you can install automatically from the plugin server:
该文件不是可执行文件。您可以从IDE中安装,在“工具”菜单“插件”下,可以检查是否有新的更新,或者在“下载”选项卡下,单击“添加插件”,然后选择下载的文件并安装。
以上来自于百度翻译 以下为原文 The file is not an executable file. You can install it from the IDE, under Tools menu, Plugins, you can check for new updates or under the downloaded tab, click add plugin, then you can select your downloaded file and install it. |
5283 浏览 9 评论
2055 浏览 8 评论
1968 浏览 10 评论
3231 浏览 3 评论
2276 浏览 5 评论
820浏览 1评论
708浏览 1评论
652浏览 1评论
709浏览 0评论
605浏览 0评论
GMT+8, 2025-1-11 15:37 , Processed in 1.050655 second(s), Total 78, Slave 62 queries .
