我正试图了解ADC触发从PWM到ADC的工作原理。这是我迄今为止得到的:PWM设置:ADC设置:为什么tiG1需要在356和3144之间以获得每个PWM周期的触发?在上面或下面,它每2个周期移动到1个触发点。我在DSSPIC33 EP128MC204MPLABX 3.35Win 7XC16V1.26上进行测试。
以上来自于百度翻译 以下为原文 I'm trying to learn how the ADC triggering works from pwm to adc. Here's what I've got so far: PWM Setup: //Timing PTCON = 0; //pwm module disabled PTCON2 = 0; // Divide by 1 to generate PWM PHASE1 = (FCY/FPWM - 1); //FCY = 70000000, FPWM = 20000 PHASE2 = (FCY/FPWM - 1); PHASE3 = (FCY/FPWM - 1); PDC1 = PHASE1 / 2; PDC2 = PHASE1 / 2; PDC3 = PHASE1 / 2; // Initialize as 0 voltage //PWM Gen Control PWMCON1 = 0; //default PWMCON1bits.CAM = 1; //center aligned PWMCON1bits.ITB = 1; //PHASEx provides time base for this pwm generator PWMCON1bits.MDCS = 0; //PDCx register provides duty for this generator PWMCON2 = PWMCON1; //see above PWMCON3 = PWMCON1; //see above PWMCON1bits.TRGIEN = 1; //this triggers the PWM1 Interrupt (Not other peripherals) //IO Control IOCON1 = 0; //default IOCON1bits.PENH = 1; //pwm h controlled by pwm module IOCON1bits.PENL = 1; //pwm l controlled by pwm module IOCON1bits.POLH = 0; //pin active high IOCON1bits.POLL = 0; //pin active high IOCON1bits.PMOD = 0; //complementary mode IOCON1bits.OVRENH = 0; //not overridden by OVERDAT IOCON1bits.OVRENL = 0; //not overriddden by OVERDAT IOCON2 = IOCON1; //see above IOCON3 = IOCON1; //see above //Dead time control DTR1 = 0; //not used in this mode DTR2 = DTR1; //not used in this mode DTR3 = DTR3; //not used in this mode ALTDTR1 = ALTDTR_DIV2 << 1; //ALTDTR_DIV2 = 150 ALTDTR2 = ALTDTR1; ALTDTR3 = ALTDTR1; //Trigger TRIG1 = 355; //If I set this to 356 it works, 355 or lower and it does not TRGCON1bits.TRGDIV = 0; //trigger on every match event TRGCON1bits.TRGSTRT = 0; //trigger on first match event //Fault control FCLCON1 = 0; //default FCLCON1bits.FLTMOD = 3; //Fault input is disabled FCLCON1bits.CLMOD = 0; //Current limit mode is disabled FCLCON2 = FCLCON1; //see above FCLCON3 = FCLCON1; //see above //Run PTCONbits.PTEN = 1; //enable pwm ADC Setup: //Analog Channels: ANSELA = 3; ANSELB = 3; ANSELC = 4; AD1CON1 = 0; AD1CON1bits.ASAM = 1; //auto start sampling AD1CON1bits.FORM = 3; //Signed Fractional AD1CON1bits.SIMSAM = 1; //simultaneous sampling (10b only) AD1CON1bits.SSRCG = 1; //SSRC Selection Group: 0,1,2: PWM[1,2,3] Prim Trig, 3,4,5,6: PTGO[12,13,14,15] Primary Trigger] AD1CON2 = 0; AD1CON2bits.CHPS = 2; //convert CH0,CH1, CH2, CH3 AD1CON2bits.SMPI = 1; //generate interrupt after 4th conversion AD1CON2bits.ALTS = 1; //use channel input select for sample MUXA on first Sample, MUXB on next Sample /* Set Samples and bit conversion time */ AD1CON3 = 0; AD1CON3bits.SAMC = 3; //Auto Sample Time = 3 Tad AD1CON3bits.ADCS = 6; //7*Tp = Tad (NOT USED) AD1CSSH = 0; AD1CSSL = 0; AD1CSSLbits.CSS3 = 1; AD1CSSLbits.CSS8 = 1; AD1CHS0bits.CH0SA = 3; //AN3 connected to Channel 0 MUXA IFS0bits.AD1IF = 0; //reset interrupt flag IEC0bits.AD1IE = 1; //enable interrupt AD1CON1bits.ADON = 1; //turn on ADC module Why does TRIG1 need to be between 356 and 3144 to get a trigger every pwm period? Above or below that it moves to 1 trigger every 2 periods. I am testing this on a dspic33ep128mc204 MPLABX 3.35 Win 7 XC16v1.26 |
你用的是哪种芯片?在FRM手册中,max Fcy=60兆赫,在您的代码中,您提到了Fcy=70MHz。你能尝试改变这个值并检查行为吗?
以上来自于百度翻译 以下为原文 |
5427 浏览 9 评论
2126 浏览 8 评论
2042 浏览 10 评论
3295 浏览 3 评论
2338 浏览 5 评论
931浏览 1评论
798浏览 1评论
751浏览 1评论
806浏览 0评论
693浏览 0评论
GMT+8, 2025-4-6 06:02 , Processed in 1.131769 second(s), Total 75, Slave 59 queries .
