我们没有任何项目或应用笔记的GSM调制解调器。然而,很容易通过UART将任何GSM调制解调器与PSoC接口。任何GSM调制解调器都可以接受来自PSoC的命令。这些命令被称为AT命令。不同的AT命令从PSoC发送到GSM调制解调器的解释不同,调制解调器执行适当的操作。因此,与PSoC接口的GSM调制解调器的一种可能实现是将GSM调制解调器连接到PSoC的RX和TX线路并发送AT命令。每个GSM调制解调器数据表提供了一组调制解调器可以接受的AT命令。通过这个数据表,并从PSoC发送这些命令。
以上来自于百度翻译 以下为原文 We do not have any project or App Note for GSM modem. However, it is easy interface any GSM modem with PSoC via UART. Any GSM modem can accept commands from PSoC. These commands are called AT commands. Different AT commands sent from PSoC to GSM modem is interpreted differently and the modem performs suitable operation. Hence, a possible implementation to interface GSM modem with PSoC is to connect, the GSM modem to RX and TX lines of PSoC and send AT commands. Each GSM modem datasheet provides a set of AT Commands that the modem can accept. Go through this datasheet and send these commands from PSoC. |
嗨,Cbraj,
您可以下载UART上的一个示例项目,并修改它来发送ATM命令来发送和接收来自GSM调制解调器的文本消息。 您可以将GSM调制解调器连接到PC机,通过超终端发送和接收文本消息。在这种情况下,UART用于GSM调制解调器和PC.之间的通信。 当您与PSoC连接GSM调制解调器时,您正在用PSoC替换PC,以便UART用于通过PSoC向GSM调制解调器发送AT命令。 以上来自于百度翻译 以下为原文 Hi Cbraj, You can download a sample project on UART and modify it to send AT commands to send and receive text messages from GSM Modem. You can connect the GSM modem to a PC to send and receive text messages via Hyperterminal. In this case UART is used for communication between the GSM modem and PC. When you are interfacing the GSM Modem with PSoC, you are replacing the PC with PSoC so that the UART is used to send AT commands to GSM modem by PSoC. |
你使用开发工具包吗?哪一个?你使用的是哪个版本的创建者????
鲍勃 以上来自于百度翻译 以下为原文 Are you using a development kit? Which one?? Which version of Creator are you using??? Bob |
先生我用Axios 1.0 psoc5基础开发包,其PSoC Creator 2.2
以上来自于百度翻译 以下为原文 sir im using AXIOS 1.0 PSOC5 based development kit, and its psoc creator 2.2 |
SIR使用PSoC 5LP,DIICE CY8C5868 AX1-LP035,当我想将GSM模型与PSoC板进行接口时,在设备MnNaGER中,端口或其他设备选项不意味着在PSoC板和LopTopTM之间连接时不检测USB电缆。我想我没有设备驱动程序可以帮助我的任何机构下载该设备驱动程序软件。
这是Psoc dovelopent套件,是PSoC创作者2.2版。请帮我下载这个版本的驱动程序SopfTWAL。 以上来自于百度翻译 以下为原文 sir im using psoc 5lp, divice cy8c5868ax1-lp035, when i want to interface gsm model with psoc board , In the device mannager there port or other device option is not there means its not detecting u*** cable, When connected between psoc board and loptop. i think i did not have device driver can help me any body to download that device driver softwere. This is Psoc dovelopent kit that is psoc creater 2.2 version. please help me to download driver sopftware for this version. |
创建者2.2支持5LP,从下面的发行说明
然而,鲍伯是正确的,3修复错误和组件在2.2,最新版本 应尽可能使用。 问候,Dana。 以上来自于百度翻译 以下为原文 Creator 2.2 does support 5LP, from the release notes below - However Bob is correct, 3.0 fixes bugs and components in 2.2, latest release should be used whenever possible. Regards, Dana. |
先生这是我的项目,我通过UART接口连接做cable.the GSM调制解调器是串口电缆GSM Modem和MAX232卡之间,最大卡连接到PSoC板4pins TX和RX,和USB系统电缆PC和PSoC boar之间,所以我想发送和接收GSM调制解调器的信息,请给我这个节目。
以上来自于百度翻译 以下为原文 sir this is my project , im doing interface gsm modem through UART cable.the connection are UART cable between gsm modem and max232 card, the max card have 4pins Tx and Rx connected to psoc board, and USBFS cable between pc and PSoC boar,so i want to send and recieves messages from gsm modem, please send me program for this . |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
275浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 00:47 , Processed in 0.784828 second(s), Total 60, Slave 54 queries .
