有没有一种直截了当的方法来为先锋提供3.6V电源?我尝试过多种方法,但没有多少成功。应用3.6V到VIN似乎毫无用处。通过USB端口应用它并不能提供足够的电源,所以其中一盏灯亮起,但没有做太多的事情。它似乎通过3.3V-EXT作品应用3.3V-3.4V,但机载保护电路关闭板时,我得到约3.47伏(使用台式电源测试)。
有没有直接向3.6V供电的电路板,而不需要外部调节电路? 以上来自于百度翻译 以下为原文 Is there a straight-forward way to power the Pioneer from a 3.6V power supply? I have tried multiple methods of doing so without much success... Applying 3.6V to Vin seems to do nothing. Applying it through the USB port does not provide enough power and so one of the lights dimly lights up, but doesn't do much else. It seems applying 3.3V-3.4V through the 3.3V EXT works, but the onboard protection circuitry shuts off the board when I get to about 3.47V (tested using a bench power supply). Is there a straight-forward method of powering this board with 3.6V without needing to result to external regulation circuitry? |
4个回答
用户手册展示和讨论配电
以上来自于百度翻译 以下为原文 The user manual shows and discusses power distribution - |
附图
PSoC 4配电先驱 76.3 K 以上来自于百度翻译 以下为原文 Picture attached |
你的3.6V电源稳定吗?它被外部监管了吗?
如果它是稳定的,我建议您通过3.3VXEXT引脚馈送它,并用零欧姆电阻器填充未填充的R48来绕过保护电路。 也许在R48焊接低VF二极管将更好地保护您的源从反向放电和电压下降到3.3V左右。 以上来自于百度翻译 以下为原文 is your 3.6v source stable? has it been externally regulated or anything? If it is stable I would recommend you feeding it through the 3.3v_ext pin and populating the unpopulated R48 with a Zero ohm resistor to bypass the protection circuitry. Probably soldering a low Vf diode in R48 would be even better by protecting your source from reverse discharging and dropping the Voltage to around 3.3v |
顺便说一下,通过USB输入3.6V源,你是否尝试将J9设置为VBUS而不是3.3?这样,你绕过调节器和全3.6V(减去肖特基二极管下降)出现在VDD上。
以上来自于百度翻译 以下为原文 BTW While feeding your 3.6v source through USB did you try setting J9 to VBUS instead of 3.3? that way you bypass the regulator and the full 3.6v (minus the schottky diode drop) appear on VDD. |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1549 浏览 1 评论
605浏览 2评论
451浏览 2评论
448浏览 2评论
400浏览 2评论
1082浏览 2评论
GMT+8, 2025-1-12 03:21 , Processed in 0.749681 second(s), Total 50, Slave 45 queries .
