有关SALES /产品/设备选择问题,请联系我们的Xilinx /分销商现场应用工程师(FAE)。
它们将帮助您更好地选择设备。 您可以从以下链接http://www.xilinx.com/company/sales/ww_disti.htm获取它们的详细联系信息。 (该链接可以指导以下的autherized分销商链接http://www.xilinx.com/company/contact/auth-disti-table.htm) _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 For SALES/ Product/Device selections issues please contact our Xilinx/Distributors Field Application Engineers (FAE). They will help you in better way for device selection. You can get contact details of them from the following link http://www.xilinx.com/company/sales/ww_disti.htm. (That link can guide to the following autherized distributers link http://www.xilinx.com/company/contact/auth-disti-table.htm) ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
链接是一个谷歌图像搜索,显示了许多不同的板。
究竟哪一个你想买? ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The link was to a google image search that showed many different boards. Exactly which one are you trying to buy?------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
亲爱的先生
我想尝试数字闹钟。 需要在液晶显示屏上显示的时间。 这是我的最后一年项目。 请帮帮我 :( 以上来自于谷歌翻译 以下为原文 dear sir i want to try digital alarm clock. the time need to show on the LCD display. that is my final year project. please help me :( |
您可能有预算而且不需要最新家族开发板上的高级功能,因此我建议您使用Xilinx Spartan-3A入门套件。
http://www.xilinx.com/products/boards-and-kits/HW-SPAR3A-SK-UNI-G.htm这应该在Avnet有库存,以便快速发货.http://avnetexpress.avnet.com/ ?存储/ EM / EMController行动=产品和安培;采用catalogId = 500201&安培; STOREID = 500201&安培; N = 0&安培; LANGID = -1&安培; slnk = C&安培;术语= HW-SPAR3A-SK-UNI-G ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 You are likely on a budget and don't need the advance features that are found on the latest family development boards, so I suggest that you get the Xilinx Spartan-3A starter kit. http://www.xilinx.com/products/boards-and-kits/HW-SPAR3A-SK-UNI-G.htm this should be in stock at Avnet for quick shipment. http://avnetexpress.avnet.com/store/em/EMController?action=products&catalogId=500201&storeId=500201&N=0&langId=-1&slnk=c&term=HW-SPAR3A-SK-UNI-G ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
我不认为它有一个压电蜂鸣器,所以你需要买一个并连接到电路板上。
购买前请仔细阅读主板用户指南,以确保满足您的需求。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 I don't think that it has a piezoelectric buzzer, so you would need to buy one and connect it to the board. Read through the board user guide before buying to make sure that it meets your needs. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
Digilent,Inc。提供了一些很好的学习平台,他们在新加坡有一个经销商(seehere)。
如果使用Spartan 6是您项目的一项硬性要求,您可以使用他们的NEXYS 3开发板。 它没有蜂鸣器,但你可以添加一个带有放大器的音频插孔,并附加他们称为PMOD的外围模块。 如果不需要Spartan 6,还有其他Xilinx FPGA开发板(见此处),它们具有PMOD的显示,开关,按钮和I / O,其成本低于NEXYS 3平台。 -约旦 这个签名故意留空。 以上来自于谷歌翻译 以下为原文 Digilent, Inc. makes some good learning platforms and they have a distributor in Singapore (see here). If using a Spartan 6 is a hard requirement of your project, you can use their NEXYS 3 development board. It doesn't have a buzzer, but you can add an audio jack with amplification with their add on peripherial modules they call PMODs. There are other Xilinx FPGA development boards (see here) that have displays, switches, buttons, and I/O for PMODs that cost less than the NEXYS 3 platform if the Spartan 6 isn't a requirement. -Jordan This signature intentionally left blank. |
2591 浏览 7 评论
2920 浏览 4 评论
2372 浏览 9 评论
3472 浏览 0 评论
2552 浏览 15 评论
3074浏览 1评论
717浏览 1评论
593浏览 1评论
881浏览 0评论
GMT+8, 2025-4-15 05:46 , Processed in 1.317791 second(s), Total 63, Slave 57 queries .
