你好,
RESET引脚是否有内部上拉? 当它漂浮在我的STA311B上时,似乎RESET引脚上总是“0”......当我试图用外部电阻将其上拉到VCC时,它会下降到15 mA。这是否意味着我的STA311B是吐司?当VDD的主电源下降时,是否会给RESET引脚施加幻象电源? #reset#sta311b 以上来自于谷歌翻译 以下为原文 Hello, Does the RESET pin have an internal pull-up? It seems that there's always ''0'' on RESET pin when it's floating on my STA311B... And it sinks up to 15 mA when I'm trying to pull it up to VCC with external resistor. Does it mean that my STA311B is toast? Could it be the consequences of phantom power given to RESET pin while the main supply to VDD was down? #reset #sta311b |
嗨奥马莱,
这是一个施密特触发器缓冲输入。所以不会正常下沉如此高的电流。 通常一个10K欧姆的上拉电阻足以用于复位引脚,并且还需要在IC引脚附近添加1nF MLCC芯片电容,以防止ESD或接地噪声意外复位。 谢谢 YT 以上来自于谷歌翻译 以下为原文 hi Omalay, it's a schmitt trigger buffered input . so will not sink such high current normally . usually a 10K ohm pulled up resistor was enough for reset pin , and you also need to add a 1nF MLCC chip capacitor nearby IC pin to prevent unexpected reset by ESD or noise from ground . Thanks YT |
2422 浏览 1 评论
3138 浏览 1 评论
1707 浏览 1 评论
3520 浏览 6 评论
5878 浏览 21 评论
863浏览 4评论
1240浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
507浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1222浏览 3评论
1276浏览 3评论
GMT+8, 2024-9-22 09:29 , Processed in 0.796795 second(s), Total 43, Slave 38 queries .
