嗨,PSOC4的一个局限性是,它不可能使用时钟信号来实现时钟以外的任何其他目的。我需要一个门控时钟输出为我的组件。我知道通常的方法是使用一个比需要快两倍的时钟,但我怀疑是否可以用另一种方式。我试图在Verilog中实现一个“任何边缘T-FF”,它在编译设计时被“接受”,但是它引发了一个关于组合循环的通知。我还没有测试,如果这真的有效,我首先想弄清楚哪一个是更好的方法。如果我必须使用两倍更快的时钟,它是如何在组件中实现的?目前,我有一个状态机对每一个时钟脉冲作出反应,但如果上述适用,我的组件必须只对每第二个时钟脉冲作出反应。问候,Ralf
以上来自于百度翻译 以下为原文 Hi, one of the PSoC4 limitations is that it's not possible to use a clock signal for any other purpose than clocking a component. I need a gated clock output for my component. I know that the usual way would be to use a clock two times faster than needed, but I wonder if it's possible by another way. I tried to implement a "any-edge T-FF" in Verilog, which is "accepted" when compiling the design, but it throws a notice about a combinational loop. I haven't tested yet if this really works, I first want to figure out which is the better way. If I have to use a two times faster clock, how is it implemented in the component? Currently I've a state machine which reacts on every clock pulse, but if the above applies, my component must only react on every 2nd clock pulse. Regards, Ralf |
PSoC SESESEI有一个很好的博客文章,关于在PSoC4中处理时钟的数据:HTTP://wwwyCysP.COM/?RID=80799
也许它可以帮助你(即使他没有直接解释门控时钟,你可以很容易地把它添加到例子中)。 以上来自于百度翻译 以下为原文 PSoC Sensei has a nice blog post about handling clocks as data in PSoC4: http://www.cypress.com/?rID=80799 Maybe it helps you out (even though he doesn't directly explain gating a clock, you can easily add this to the examples). |
嗨,哈里,谢谢你。在阅读了博客和几个论坛帖子后,我认为这是使用输入时钟的最佳方式,输入时钟是输出频率的两倍。问候,Ralf
以上来自于百度翻译 以下为原文 Hi hli, thank you. After reading the blog and several forum threads I think it's the best way to use an input clock which is twice the output frequency. Regards, Ralf |
760个成员聚集在这个小组
加入小组2160 浏览 1 评论
1909 浏览 1 评论
3732 浏览 1 评论
1841 浏览 6 评论
1589 浏览 1 评论
797浏览 2评论
555浏览 2评论
493浏览 2评论
452浏览 2评论
1309浏览 2评论
GMT+8, 2025-3-10 18:43 , Processed in 1.498773 second(s), Total 77, Slave 61 queries .
