大家好,
是否有一些用于TDM控制器的IP内核,我尝试使用opencore的tdm控制器,因为它的FIFO使用Altera内核,我不能在Xilinx中使用它,所以,我担心Xilinx区域的Opencore TDM控制器是否有相同的功能? 谢谢 以上来自于谷歌翻译 以下为原文 Hi All, Is there some IP core for the TDM controller, i tried the opencore's tdm controller, as its FIFO used Altera core, i can not use it in Xilinx, so, i am wordering is there same to Opencore's TDM controller in Xilinx area? Thank you |
您好
Xilinx没有任何用于TDM控制器的IP内核。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 HI Xilinx doesn't have any IP cores for TDM controller. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
谢谢Yenigal。
正如我所提到的,我在Altera中尝试过opencores TDM控制器并且可以在Quartars中编译,但是附加缓冲区代码无法在ISE14.6中编译,总是显示我“INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - 进程将终止。对于威廉希尔官方网站 支持 在这个问题上,请打开一个WebCase,该项目附在http://www.xilinx.com/support上。“ 因为我是VHDL的新手,有没有人可以帮我弄清楚我需要修复附加代码的哪一部分才能在ISE中编译? (或参考opencore http://opencores.org/project,tdm,overview中的代码) 谢谢 SPMEM.VHD 15 KB RxTDMBuff.vhd 7 KB TxTDMBuff.vhd 7 KB 以上来自于谷歌翻译 以下为原文 Thanks Yenigal. As i mentioned i tried opencores TDM controller in Altera and can compiled in Quartars, but attached buffer codes can not compiled in ISE14.6, always shown me "INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support." as i am a newbie for the VHDL, does anyone can help me figure out which part i need to fix attached codes to get compiled in ISE? (or refer to the codes in opencore http://opencores.org/project,tdm,overview) Thank you SPMEM.VHD 15 KB RxTDMBuff.vhd 7 KB TxTDMBuff.vhd 7 KB |
2483 浏览 7 评论
2864 浏览 4 评论
2324 浏览 9 评论
3410 浏览 0 评论
2506 浏览 15 评论
2276浏览 1评论
647浏览 1评论
512浏览 1评论
2059浏览 0评论
787浏览 0评论
GMT+8, 2025-2-9 08:05 , Processed in 1.296483 second(s), Total 45, Slave 40 queries .
