嗨,
我正在使用Xilinx Spartan 6 FPGA进行原理图设计。 我从USB和连接器上接到5V电路板。 我想用它作为我的FPGA的输入,表明USB连接器已连接。 我计划使用分压器从这个5V获得3.3V电压,但我很难找到输入电流进入FPGA上的LVCMOS33输入。 有人可以帮忙吗? 谢谢, 卡皮尔 以上来自于谷歌翻译 以下为原文 Hi, I am doing the schematic design using a Xilinx Spartan 6 FPGA. I have a 5V coming on to my board from u*** and connector. I want to use this as an Input to my FPGA indicating the USB connector is connected. I plan to use a voltage divider to get 3.3V from this 5V but I am struggling to find the Input current going in to a LVCMOS33 input on the FPGA. Can anyone help? Thanks, Kapil |
3个回答
K,
它是+/- 10uA,数据手册中的IO引脚泄漏规范。 Austin Lesea主要工程师Xilinx San Jose 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 K, It is +/- 10uA, the IO pin leakage specification in the data sheet. Austin Lesea Principal Engineer Xilinx San JoseView solution in original post |
K,
它是+/- 10uA,数据手册中的IO引脚泄漏规范。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 K, It is +/- 10uA, the IO pin leakage specification in the data sheet. Austin Lesea Principal Engineer Xilinx San Jose |
这是正确的答案吗?
漏电流是指输入晶体管被驱动为低电平或关闭时的电流。 我认为Kapil问输入晶体管导通时的输入电流消耗是多少? 我查看了斯巴达6数据表,但找不到答案。 由于FPGA的输入会看到输入晶体管的栅极,因此它将是高阻抗。 如果存在内部输入终端,则会消耗一些电流。 有没有办法弄清楚输入电流消耗是多少? 以上来自于谷歌翻译 以下为原文 Is this is the correct answer? Leakage current is when the input transistor is driven low or is off. I think Kapil is asking whats the input current consumption when the input transistor is on? I looked through the spartan 6 datasheet and could not find the answer. Since the input of the FPGA would see the gate of the input transistor, it would be high impedance. If there is an internal input termination this would consume some current. Is there a way to figure out what the input current consumption would be? |
2583 浏览 7 评论
2916 浏览 4 评论
2371 浏览 9 评论
3468 浏览 0 评论
2549 浏览 15 评论
3041浏览 1评论
714浏览 1评论
586浏览 1评论
878浏览 0评论
GMT+8, 2025-4-12 08:00 , Processed in 1.366071 second(s), Total 81, Slave 65 queries .
