我们的D600是移动HF(13.56 MHz)读卡器,蓝牙连接到iOS,Android或Windows设备。
https://www.socketmobile.com/products/durascan/600-series/d600 我们正在为D600阅读器添加NFC Forum Type 5支持。对ST25TV512,ST25TV02K,ST25TV02K-AD和ST25TV64K的一些要求似乎与NFC论坛的“Type 5标签威廉希尔官方网站 规范”(版本1.0 2017-09-09)相冲突。 这是询问详细实施问题的地方吗? #nfc-tags #nfc 以上来自于谷歌翻译 以下为原文 Our D600 is a Mobile HF (13.56 MHz) Reader that is Bluetooth connected to an iOS, Android, or Windows device. https://www.socketmobile.com/products/durascan/600-series/d600 We are adding NFC Forum Type 5 support to our D600 Reader. Some requirements for the ST25TV512, ST25TV02K, ST25TV02K-AD, and ST25TV64K 'seem' to conflict with the NFC Forum 'Type 5 Tag Technical Specification' (Version 1.0 2017-09-09). Is this the place to ask detailed implementation questions? #nfc-tags #nfc |
亲爱的顾客,
ST25TV已通过NFC论坛认证。 请参阅NFC论坛证书: https://nfc-forum.org/wp-content/uploads/2017/08/STMicro_ST25TV_CertID_58519-1.pdf 您能否解释哪些要求似乎与NFC论坛的“Type 5标签威廉希尔官方网站 规范”相冲突? 问候 以上来自于谷歌翻译 以下为原文 Dear customer, ST25TV has been certified by the NFC Forum. Please refer to NFC Forum certificate: https://nfc-forum.org/wp-content/uploads/2017/08/STMicro_ST25TV_CertID_58519-1.pdf Could you please explain which requirements seem to conflict with the NFC Forum 'Type 5 Tag Technical Specification' ? Regards |
2741 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3653 浏览 6 评论
6043 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
446浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 12:19 , Processed in 1.234239 second(s), Total 78, Slave 62 queries .
