什么“2D端口求解器数据不适用于厚导体馈线,使用默认值(50欧姆)作为传输线参数”是指,同时使用动量模拟微带滤波器?编辑:Vinothkumar于2012年8月14日
上午5:03 以上来自于谷歌翻译 以下为原文 what does "the 2D port solver data is not available for thick conductor feed lines, using default values(50 ohms) for the transmission line parameters" mean, while simulating a micro strip filter using momentum ? Edited by: Vinothkumar on Aug 14, 2012 5:03 AM |
该消息基本上意味着由于为导体选择的粗导体选项,Momentum将不计算连接到端口的布局中的一个或多个传输线的特征阻抗。
您仍然可以从Momentum获得参考50欧姆的s参数,并参考设置到每个端口的阻抗。 以上来自于谷歌翻译 以下为原文 This message basically means that Momentum will not compute the characteristic impedance of one or more of the transmission lines in the layout that is connected to a port due to the thick conductor option chosen for the conductor. You will still get s-parameters from Momentum that are referenced to 50 Ohms, and referenced to the impedance set to each port. |
1342 浏览 0 评论
2400 浏览 1 评论
2227 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1279浏览 1评论
788浏览 0评论
1072浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-25 04:01 , Processed in 1.504950 second(s), Total 75, Slave 59 queries .
