HiI希望每秒钟从单个频道读取数据,我必须显示它们,因为我想从特定频道获取读数,即使路径扫描中有很多频道。任何人都可以帮我解决这个问题吗?
以上来自于谷歌翻译 以下为原文 Hi I want readings from the single channel in every second and i have to display them,for that i wanted to get readings from perticular channel even tho many channels are in the route scan.can any one help me regarding this? |
3个回答
为此,您需要在每次扫描后读取所有数据,解析出所需的通道并显示它。
如有必要,我可以为此提供一个示例程序。 如果您需要,请告诉我仪器和多路复用器型号。 您使用的编程环境是什么? 如果这是一个Benchlink DataLogger问题,您可以通过设置图形来绘制一个通道的图形,然后转到“首选项”并选中“显示数据表弹出窗口”框。 以上来自于谷歌翻译 以下为原文 To do this, you read all the data out after every scan, parse out the channel you want and display it. I can provide an example program for this if necessary. If you want this, tell me the instrument and multiplexer model numbers. What programming environment are you using? If this is a Benchlink DataLogger question, you do this by setting up the graph to graph the one channel and you can go to Preferences and check the box for "Show Data Table Popup". |
是的,例子可能对我有所帮助,我希望你完全理解我的问题。值得我想显示每一秒的变化,因为一些输入,例如电压通道。所以我也需要每秒扫描一次通道。
我使用的是34970A数据记录器(hp),GPIB接口和C#。 以上来自于谷歌翻译 以下为原文 Yes,example may be helpfull for me,i hope you have understand my problemm fully.Value i wanted to display changes for every second because of some input,for examples voltage channel.So tht i need to scan channel for every sec as well. I am using 34970A Data Logger(hp),GPIB interface and C#. |
这是一个C#示例。
你需要输入“等待1秒钟”。 我是C#的新手,无法让它工作。 以上来自于谷歌翻译 以下为原文 Here's a C# example. You need to put in the "wait for 1 second part". I'm new to C# and couldn't get that to work. 附件
1291 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2065 浏览 5 评论
2952 浏览 3 评论
1127浏览 1评论
758浏览 0评论
936浏览 0评论
1294浏览 0评论
GMT+8, 2024-12-26 11:44 , Processed in 1.396514 second(s), Total 81, Slave 65 queries .
