嗨,
我是Xilinix FPGA设计的新手。 我已经加载了Web包软件并首次运行了ISE项目管理器 我收到一条错误消息,说未找到许可证 在选择“查找现有许可证(通过电子邮件发送给我的许可证已存储在我的PC上)”时,我收到“无法将许可权限加载到可信存储”的消息。 我会感激任何帮助,因为我现在陷入困境并且非常令人沮丧。 以上来自于谷歌翻译 以下为原文 Hi, I'm new to Xilinix FPGA design. I have loaded the web pack software and ran the ISE Project Manager for the first time I receive an error saying license was not found On selecting "locate existing licence ( the license Emailed to me has already been stored on my PC) I receive the messsage "Unable to load licence rights into trusted storage". I would be grateful for any help as I am stuck at the moment and its very frustrating. |
您好,可以在此附加许可证文件吗?错误消息“无法将许可证权限加载到可信存储中”表示您正在使用激活许可证。因为您使用的是ISE,您必须生成ISE许可证i..e,基于证书
license.Thanks,维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello, Can you attach your license file here? The error message "Unable to load licence rights into trusted storage" indicates that you are using activation license. Since you are using ISE, you have to generate ISE license i..e, certificate based license. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2474 浏览 7 评论
2860 浏览 4 评论
2321 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2154浏览 1评论
644浏览 1评论
504浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-2 23:27 , Processed in 1.271162 second(s), Total 42, Slave 37 queries .
