可以提交申请说明吗?
为ST ST25RU3993提供ST软件模块? 以上来自于谷歌翻译 以下为原文 May an application note? Provide ST a software module for the ST25RU3993? |
8个回答
根据我从ST的威廉希尔官方网站
支持获得的信息,该部分没有演示板或参考设计。然而,当这个系列由AMS拥有时,曾经有AS3993 FERMI板作为AS3993的参考。鉴于ST25RU3993基于AS3993,我认为FERMI板应兼容。截至目前,没有可用的数据(我知道)可以访问这些设计。如果有人遇到这些设计文件,请分享。
以上来自于谷歌翻译 以下为原文 According to the information I got from ST's technical support, there is no demo board or reference design for this part. However, back when this series was owned by AMS, there used to be AS3993 FERMI board as a reference for AS3993. Given that ST25RU3993 is based on AS3993, I assume the FERMI board should be compatible. As of now there is no data available (that I know of) to access those designs. If anyone comes across those design files please do share. |
感谢您的信息。我们与ST的销售人员会面。他们为2017年第4季度的ST25RU3993计划了一个发现套件。可能他们也提供了一个控制ST25RU3993的固件。
以上来自于谷歌翻译 以下为原文 Thanks for the Information. We had a meeting with sales people from ST. They plan a discovery kit for the ST25RU3993 for the 4th quarter 2017. May be they offer also a Firmware to control the ST25RU3993. |
嗨弗里茨,
ST团队的任何更新。我们正在拼命寻找设计RFID阅读器的开发工具。 PL。如果有更新,请分享。是否有任何直接的方法可以快速使用ST25RU3993(手工焊接)来制作原型? 谢谢! 以上来自于谷歌翻译 以下为原文 Hi Fritz, Any updates from ST team. We are desperately searching for development tools to design RFID reader. Pl. share if there is an update. Is there any straight forward method to use ST25RU3993 (by hand solder) quickly to make a prototype ? Thank you! |
嗨Rak,
ST团队的最新信息是ST25RU3993的发现套件计划于2018年第1季度末完成。 以上来自于谷歌翻译 以下为原文 Hi Rak, our last information from ST team is that the discovery kit for ST25RU3993 is planned for end of 1th quarter 2018. |
也许我可以提供帮助,我有AMS评估板的原理图。
如果你发送电子邮件给 邮寄地址:karstenpil@gmail.com, 我可以把这个原理图发给你 以上来自于谷歌翻译 以下为原文 Maybe I can help, I do have schematics for an evaluation board from AMS. if you send an email to mailto:karstenpil@gmail.com, I can send this schematic to you |
矽控电子有一款基于ST25RU3993芯片,并且兼容arduino UNO接口的模块。它提供原理图,源代码的。
超高频UHF RFID收发芯片 ST25RU3992 ( AS3992 ) 与 ST25RU3993 ( AS3993 )威廉希尔官方网站 参数对比 http://iot.eleckits.com/tech/shownews.php?lang=cn&id=95 SiliControl Electronics has a module based on ST25RU3993 chip and compatible with arduino UNO interface. It provides schematics, source code. Technical parameters comparison of UHF RFID transceiver chip ST25RU3992 (AS3992) and ST25RU3993 (AS3993) http://iot.eleckits.com/tech/shownews.php?lang=cn&id=95 |
2413 浏览 1 评论
3129 浏览 1 评论
1698 浏览 1 评论
3511 浏览 6 评论
5867 浏览 21 评论
856浏览 4评论
1231浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
499浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1213浏览 3评论
1268浏览 3评论
GMT+8, 2024-9-20 16:37 , Processed in 1.308493 second(s), Total 57, Slave 52 queries .
