大家好。我想知道是否可以使用具有感性负载的CS30电流感应放大器,即类似于自动汽车变速箱中使用的螺线管线圈。提前致谢。
工作条件为12V,约为1至2A。 以上来自于谷歌翻译 以下为原文 Hello everyone. I would like to know if is possible to use the CS30 current sense amplifier with inductive loads, i.e. something similar to the coils of solenoids used in automatic car gearboxes. Thanks in advance. The operating conditions are 12V and about 1 to 2A. |
, 你好尼古拉斯,非常感谢你的详细解答,也非常有用。在这种情况下,我可以采取另一种不昂贵的解决方案吗?让我来描述一下我的最终申请: 本质上,我希望能够使用微控制器(特别是ST Microelectronics,STM32F103C8)通过PWM和ADC反馈精确控制流过电磁阀的电流。现在我试图设计感应电阻和ADC输入之间的接口,以便使用PID控制回路。 致以最诚挚的问候,非常感谢您的所有帮助和时间。 Yosmany。 De:AUPETIT尼古拉斯 Enviado el:jueves,28 de junio de 2018 08:22 am.m. Para:YosmanyHernándezSánchez Asunto:Re: - Re:使用CS30进行感应负载电流检测。 &lt;,https://community.st.com/?et = watches.email.thread&gt ;,意法半导体社区 Re:使用CS30进行感应负载电流检测。 模拟和音频中的AUPETIT nicolas&lt;,https://community.st.com/people/AUPETIT.Nicolas?et = watches.email.thread&gt;的回复 - 查看完整的讨论&lt;,https://社区。 st.com/message/203969-re-inductive-load-current-sensing-with-cs30?commentID=203969&,et=watches.email.thread♯comment-203969>, 以上来自于谷歌翻译 以下为原文 , , Hello Nicolas, thank you very much for your detailed answer, very informative also. In this case there is another not-expensive solution I can take?. Let me describe my final application: In essence I would like to be able to precisely control the current flowing through a solenoid valve using a microcontroller (specifically from ST Microelectronics, STM32F103C8) with PWM and ADC feedback. Right now I’m trying to design the interface between sensing resistor and ADC input, in order to use a PID control loop. Best regards and thank you very much for all your help and time. Yosmany. De: AUPETIT nicolas Enviado el: jueves, 28 de junio de 2018 08:22 a.m. Para: Yosmany Hernández Sánchez Asunto: Re: - Re: Inductive load current sensing with CS30. <,https://community.st.com/?et=watches.email.thread>, STMicroelectronics Community Re: Inductive load current sensing with CS30. reply from AUPETIT nicolas <,https://community.st.com/people/AUPETIT.Nicolas?et=watches.email.thread>, in Analog and Audio - View the full discussion <,https://community.st.com/message/203969-re-inductive-load-current-sensing-with-cs30?commentID=203969&,et=watches.email.thread ♯ comment-203969>, |
3026 浏览 1 评论
3333 浏览 1 评论
1917 浏览 1 评论
3776 浏览 6 评论
6202 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
83浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
100浏览 5评论
126浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
87浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
95浏览 5评论
GMT+8, 2025-5-1 02:55 , Processed in 0.654741 second(s), Total 77, Slave 61 queries .
