Hii有一个接收器,它使用带有HSC301控件的远程控制,si想使用另一个制造商的远程控制,该制造商也用HCS301进行远程控制,远程控制工作一个(编程),但不是再次,我猜是因为它有不同的seedCan以某种方式从一个复制数据控制他人,以使之有效?
以上来自于百度翻译 以下为原文 Hi i Have a receiver, who uses remote cotrol with HSC301 control's i want to use another remotecontrol from another manufacturer that also makes remote controls with HCS301 the remote control works one (programming) but not again, i guess its because it has different seed Can somehow copy data from one control to others, in order to make it work ? |
6个回答
如果可以复制数据,我认为这可能导致控制其他遥控器什么?我认为使用HSC的目的…就是避免任何复制。
以上来自于百度翻译 以下为原文 If one could copy the data I think that might lead to taking control of what the other remote controls no ? I think the object of using the HSC... is to avoid any copying. |
我不这么认为,这就是您为设备编写任何新控件的原因,至少这是我所理解的,创建新的“克隆”设备必须为设备编程的原因!我不想对编程设备进行编程,我想使具有HCS301芯片的远程控制设备兼容,因此它可以被编程到接收器(使用自己的编程方法),就像从该接收器添加新的远程控制一样
以上来自于百度翻译 以下为原文 i dont think so, thats the reason you program any new control to device, at least that is what i have understand that 's creating a new "cloned" device will have to programed to device ! i dont want to program a programmed device i want to make a remote control device with HCS301 chip compatible so it CAN be programmed to receiver (with its own programming method) just like adding a new remotecontrol from this receiver |
你可能瞄准哪一个特定的接收器?
以上来自于百度翻译 以下为原文 And which specific receiver might you be targeting ? |
第一个遥控器有一个,我在那里没有特定的IC只有PIC和TDA7200。
以上来自于百度翻译 以下为原文 the one the first remote has. i see no specific IC only PIC in there and a TDA7200 |
第一遥控器有什么特定的“东西”?
以上来自于百度翻译 以下为原文 What specific "thing" does the first remote control ? |
没有,只是使用公司的接收器来做很多事情(报警联系人,遥控器等等),我的很多用户都有。但是他们的遥控器没有我想要的形状(形状=遥控器,带有按钮的门套),因为如果我有用户,我会搞砸。长远来看,我希望只有一个接收器到我的用户,我已经成功地焊锡HCS301从第一遥控器,和焊锡到另一个,无论我宁愿程序只第二!
以上来自于百度翻译 以下为原文 NO specific just uses Receivers from the company for a number of things (alarm contact's, remote controls etc) , a lot of my users have.however their remote controls do NOT have the shape i want for some cases (shape = remote control , with door cover for buttons) since i will mess up if i have users with that or another receiver in long term, i wand to have only one receiver to my users i have successfully solderer HCS301 from first remote control, and solder to another one, howver i would prefer to program second only ! |
5277 浏览 9 评论
2053 浏览 8 评论
1966 浏览 10 评论
3228 浏览 3 评论
2275 浏览 5 评论
812浏览 1评论
706浏览 1评论
644浏览 1评论
702浏览 0评论
600浏览 0评论
GMT+8, 2025-1-8 19:34 , Processed in 1.284097 second(s), Total 85, Slave 69 queries .
