每次在第一次“.(1)”循环之后打开代码(pic12f1572)时,我都会遇到一个奇怪的问题,代码会自动重置并重新开始。这是代码:如果有人遇到过这样的问题,请AdveBrr,丹尼尔
以上来自于百度翻译 以下为原文 i have a strange problem every time i turn on the code (pic12f1572) after the first "while (1)" loop the code reset itself and starts all over again. this is the code : void main(void) { // initialize the device SYSTEM_Initialize(); int first_delay; // When using interrupts, you need to set the Global and Peripheral Interrupt Enable bits // Use the following macros to: // Enable the Global Interrupts INTERRUPT_GlobalInterruptEnable(); // Enable the Peripheral Interrupts INTERRUPT_PeripheralInterruptEnable(); // Disable the Global Interrupts //INTERRUPT_GlobalInterruptDisable(); // Disable the Peripheral Interrupts //INTERRUPT_PeripheralInterruptDisable(); PI_DAT_SetHigh(); __delay_ms(100); PI_DAT_SetLow(); __delay_ms(100); do{ while (1){ PIR2bits.C1IF = 0; INTCONbits.IOCIE = 0; //first start delay first_delay = 0; TMR1_Initialize(); SD_SetHigh(); while (first_delay <= 5){ if (TMR1IF){ first_delay++; TMR1_Initialize(); } } //watch dog INTCONbits.IOCIF = 0; IOCAF3 = 0; INTCONbits.IOCIE = 1; tictimer = 0; TMR1_Initialize(); //start of WD for (int w=0;w<3;w++){ PI_DAT_SetHigh(); __delay_ms(100); PI_DAT_SetLow(); __delay_ms(100); } while (tictimer < 10){ //volt_sampling(); if (TMR1IF){ tictimer++; TMR1_Initialize(); } if (WD>=10){ INTCONbits.IOCIE = 0; WD=0; //test volt_sampling(); INTCONbits.IOCIE = 1; } } SD_SetLow(); __delay_ms (4000); SD_SetHigh(); } } while (1); } if any one have encountered this kind of problem please advice BR, daniel |
3个回答
为什么在地球上,如果不先编写代码来为它们提供服务,那么您能启用中断吗?
以上来自于百度翻译 以下为原文 Why on Earth are you enabling interrupts without first writing the code for servicing them? |
常见的误解,认为你必须使中断能够轮询中断标志位。
以上来自于百度翻译 以下为原文 Common misunderstanding, thinking you have to enable interrupts to be able to poll the interrupt flag bits. |
5580 浏览 9 评论
2226 浏览 8 评论
2113 浏览 10 评论
3396 浏览 3 评论
2430 浏览 5 评论
1066浏览 1评论
895浏览 1评论
914浏览 1评论
942浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
640浏览 0评论
GMT+8, 2025-7-13 16:12 , Processed in 1.339743 second(s), Total 78, Slave 62 queries .
