我使用的是CY7C65632 USB集线器。上游连接到WixPC PC,下游连接到MCU的USB D+/D,它是一个大容量存储设备的程序。有时在加电时,它会在通用USB海量存储设备下失败设备管理器代码10“设备无法启动”;有时枚举成功,并且在设备管理器中出现新的磁盘驱动器。为什么会这样?我需要一个USB集线器的驱动程序吗?谢谢您。
以上来自于百度翻译 以下为原文 I am using CY7C65632 USB hub. Upstream is connected to WinXP PC, downstream is connected to the USB D+/D- of a MCU, which is program to be a mass storage device. Sometime when powered up, it will fail Device Manager Code 10 "Device cannot start", under the Generic USB Mass Storage Device; sometimes the enumeration is successful and a new disk drive appears in Device Manager. Why is this so? Do I need a driver for the USB hub? Thank you. |
我想看一下示意图。请给我你的示意文件PRJ@ CyPress。
-普吉 以上来自于百度翻译 以下为原文 I would like to take a look at the schematic. Please get me your schematic file prji@cypress.com. -PRJI |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 16:33 , Processed in 0.581576 second(s), Total 43, Slave 38 queries .
