你好,
现在我正在使用ST8M8 Discovery板,我已经完成了一些教程并构建了一些使用PWM信号淡化LED的项目。我想将来使用SPI总线来读取和处理来自mem传感器的数据。有人可以指出我正确的方向使用SPI总线的教程,或者可能为我提供一个示例项目? 任何帮助,将不胜感激 #SPI-例子 以上来自于谷歌翻译 以下为原文 Hello, Right now im playing around with the ST8M8 Discovery board, i have followed some tutorials and have build a few projects that fade the LED using the PWM signal. I would like to use the SPI bus in the future to read and process data from a mem sensor. Could someone please point me in the right direction to a tutorial to using the SPI bus, or maybe provide me with an example project? Any help would be appreciated #spi-example |
6个回答
您可以在FWLib中使用示例
http://www.st.com/stonline/products/support/micro/files/stm8s_optimized_examples.zip brazov 以上来自于谷歌翻译 以下为原文 You can use example in the FWLib http://www.st.com/stonline/products/support/micro/files/stm8s_optimized_examples.zip brazov |
感谢快速回复,我看了一下示例,但我可以找到UART,LIN和CAN示例,但没有SPI。我忽略了什么吗?谢谢。
以上来自于谷歌翻译 以下为原文 Thanks for the fast reply, I have looked at the example, but i can find UART, LIN and CAN examples but no SPI. Am I overlooking something? Thanks. |
我有一个示例项目,我使用23K256 SRAM和STM8S Discovery。工作需要1个月,代码部分是C,部分是汇编。我没有得到ST支持的帮助,所以我需要找出自己......
以上来自于谷歌翻译 以下为原文 I have an example project where I use the 23K256 SRAM with the STM8S Discovery. It took 1 month to work, and the code is partly C, partly Assembly. I got no help from ST support, so I needed to find out myself... |
你好,
请查看STM8系列8位微控制器的文档和文件,您可以在其中找到STM8S固件库http://www.st.com/products/support/micro/files/stm8sfwlib.zip 包括STM8S的SPI外设软件示例。 问候。 以上来自于谷歌翻译 以下为原文 Hello, Please have a look at documents and files for family STM8 8-bits Microcontrollers where you can find STM8S firmware library http://www.st.com/products/support/micro/files/stm8sfwlib.zip including SPI peripheral software examples for STM8S. Regards. |
此链接无法在线获取,有人可以在网站上发送正确的链接吗?需要spi的例子...... Lior
以上来自于谷歌翻译 以下为原文 this link is not availble online , can someone send the correct link on the site ? in need a spi example ... Lior |
FWLib显然已经变得不可用了。
只有较小的标准外围设备库。 spi.c在库中。 这个博客中有一个简单的例子:http://singamicro-30-stm8s105.blogspot.com/p/new-page-1-microcontroller-stm8s105.html 但它只使用了输出。 以上来自于谷歌翻译 以下为原文 The FWLib had apparently been made UNavailable. Only a smaller Std Peripheral Library is available. The spi.c is in the library. There is a simple example in this blog: http://singamicro-30-stm8s105.blogspot.com/p/new-page-1-microcontroller-stm8s105.html But it used only the output. |
2782 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1348浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
468浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
216浏览 2评论
GMT+8, 2025-1-12 14:07 , Processed in 0.958110 second(s), Total 56, Slave 50 queries .
