11683A,E4417A(更多),N1912A(更多)10 dBm,10.02 dBm,10.03 dBm 15 dBm,15.03 dBm,15.04 dBm 20 dBm,20.06 dBm,20.08 dBm为什么不同?
不要求规格。 热电偶传感器的校正数据完全不同? ---添加内容---每个11683A,437B,E4417A,N1912A的标称值10.00 mW,10.00 mW,10.032 mW ,? 31.6 mW,31.6 mW,31.785 mW ,? 100.0 mW,100.0 mW,101.35 mW ,? 据我所知,由于热电偶传感器的非线性补偿。(437B≠E4417A)因此,10 dBm至20 dBm范围内的3%8481A规格。 我想知道的是N1912A范围的标称值。(热电偶模式)编辑:최태준on Jul 17,2012 9:07 PM 以上来自于谷歌翻译 以下为原文 11683A, E4417A(more), N1912A(more) 10 dBm, 10.02 dBm, 10.03 dBm 15 dBm, 15.03 dBm, 15.04 dBm 20 dBm, 20.06 dBm, 20.08 dBm Why the difference? Specifications are not asked. Correction data of thermocouple sensor are radically different? --- Add contents --- Nominal values of each 11683A, 437B, E4417A, N1912A 10.00 mW, 10.00 mW, 10.032 mW, ? 31.6 mW, 31.6 mW, 31.785 mW, ? 100.0 mW, 100.0 mW, 101.35 mW, ? As far as I know is due to non-linearity compensation of thermocouple sensor.(437B ≠ E4417A) Because of this, 3% in the 10 dBm to 20 dBm range 8481A specs. I want to know is Nominal Value of N1912A range.(thermocouple mode) Edited by: 최태준 on Jul 17, 2012 9:07 PM |
1342 浏览 0 评论
2400 浏览 1 评论
2227 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1285浏览 1评论
788浏览 0评论
1074浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-26 15:11 , Processed in 1.277316 second(s), Total 75, Slave 59 queries .
