您是否了解我可以配置的设备或设备,如附图中所示?
需要在15个不同的输入上测量220VAC 3ph并选择输入并通过以太网或USB向测试控制器报告电压RMS。 任何提示赞赏。 谢谢 以上来自于谷歌翻译 以下为原文 Are you aware of devices or devices I can configure as shown notionally in the attached drawing? Needing to measure 220VAC 3ph on 15 different inputs and select input and report voltage RMS via Ethernet or USB to the test controller. Any hints appreciated. thank you 附件
我想,高电压很难找到“现成的”解决方案。
也许解决方案是使用USB I / O盒控制连接到像DMM这样的测量设备的一组继电器,为您提供所需的值。 以上来自于谷歌翻译 以下为原文 The high voltage makes trouble finding an "off the shelf" solution, I guess. Maybe a solution would be to use an USB I/O box controlling a set of relays connecting to a measuring device like a DMM giving you the values needed. |
> {quote:title = rkruz写道:} {quote} ...需要在15个不同的输入上测量220VAC 3ph并选择输入并通过以太网或USB将电压RMS报告给测试控制器。
您需要一个高压输入多路复用器,如[N2270A | www.home.agilent.com/en/pd-1000003582%3Aepsg%3Apro-pn-N2270A](1000V输入),这是废弃的。 看一下[34901A | www.home.agilent.com/en/pd-1000000083%3Aepsg%3Apro-pn-34901A](300V)或者您可以考虑构建自己的(USB i / f,微控制器,驱动程序) ,继电器,布线I / O)。 以上来自于谷歌翻译 以下为原文 > {quote:title=rkruz wrote:}{quote} ... Needing to measure 220VAC 3ph on 15 different inputs and select input and report voltage RMS via Ethernet or USB to the test controller. You need a high voltage input multiplexer like the [N2270A|www.home.agilent.com/en/pd-1000003582%3Aepsg%3Apro-pn-N2270A] (1000V inputs) which is obsoleted. Take a look at the [34901A|www.home.agilent.com/en/pd-1000000083%3Aepsg%3Apro-pn-34901A] (300V) or you may consider to construct your own (USB i/f, microcontroller, drivers, relays, cabling I/O). |
1396 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2113 浏览 5 评论
3028 浏览 3 评论
1496浏览 1评论
840浏览 0评论
1259浏览 0评论
1399浏览 0评论
GMT+8, 2025-3-7 09:18 , Processed in 1.576827 second(s), Total 100, Slave 84 queries .
