嗨!
我正在尝试使用xapp495 HDMI演示......我使用的是Atlys斯巴达6板。 但我不能让它发挥作用..如果有任何人有这个核心的经验,请回复。 我真的很感激我能得到的任何帮助。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi! I am trying to use the xapp495 HDMI demo... I am using a Atlys spartan 6 board. But i coud not get it to work.. If there is anyone who has experience with this core, plese reply. I realy appreciate any help i can get. Thanks. |
您是否有机会访问以下相关论坛帖子。
他们可以为您的调试提供帮助或提供有用的提示 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=541 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=515 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=4111 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Spartan&message.id=21280 另请参阅http://www.xilinx.com/publications/prod_mktg/S6CVK2.0_ProductFAQ.pdf _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Did you get chance to below related forums posts. They may help or gives useful tips for your debugging http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=541 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=515 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=4111 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Spartan&message.id=21280 Also refer http://www.xilinx.com/publications/prod_mktg/S6CVK2.0_ProductFAQ.pdf ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2441浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 18:31 , Processed in 1.088574 second(s), Total 44, Slave 39 queries .
