嗨,大家好!
我正在尝试从硅实验室的EZADOPro改编源代码。我想通过PSoC 3为无线收发器模块RM22B(来自HOPRF),包括SI44 30芯片开发代码。 我已经开发了用ACK双向链接的代码,并用PSoC 3进行工作。 现在我想再多做一步,我希望FHSS调制(跳频扩频),所以我可以得到更好的答案,由于信号多重衰落。 Tela是来自硅实验室的一些代码,但是它们使用SDCC和CuililRyDeff.h。 “*定义节段变量(name,ValType,LoopEnter)VARTYPE段段名” 我的问题是我不知道如何在PSoC 3中使用等价的声明。 我不想复制代码,我只想知道这个声明是什么意思。 作为参考,我将在这里粘贴一个链接来看看CopySerdDuff.h是什么。 http://www. kiel.com /dd/DOCS/C51/CygNal/CuffeleR.DEFS.h 我希望有人能告诉我如何在PSoC 3上使用这个声明。 非常感谢你。 以上来自于百度翻译 以下为原文 Hi every one.! I'm tryinng to adapt source code from EZRadioPro from Silicon Lab. I want to develop code right through PSoC 3 for radio tranceiver module RFM22B,( from HopeRF) which include si4430 chip. I have alrready developed code for bidirectional link with ACK and work OK with PSoc 3. Now I would like one more step and I would like FHSS modulation( frecuency hopping spread spectrum) , so I can get better answer due to signal multifading . Thera are some code from Silicon lab , but they use SDCC and compiler_defs.h. There are for some global variable declaration such as : " # define SEGMENT_VARIABLE(name, vartype, locsegment) vartype locsegment name " My issue is that I don't known how use the equivalent declaration in PSoc 3 . I don't want to copy the code, only I want to understand what does this declartion mean. For reference I will paste here a link to take a look what compiler_defs.h does. http://www.keil.com/dd/docs/c51/cygnal/compiler_defs.h I hope someone can tell me how use this declaration on PSoC 3 Thank you very much in advance. |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1763 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
276浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 16:44 , Processed in 0.986895 second(s), Total 72, Slave 57 queries .
