大家好!
我尝试使用MixPrim3编程我的PSoC3,CY8C3245PVI-134。我有程序员设置为5针SWD编程在3.3V,自动检测,以及电源周期模式,时钟速度为1.6MHz。我的程序员软件是最新的版本。除了问题我什么也没有。 首先,当被告知要编程的芯片,自动检测不工作,所以我必须手动设置设备芯片。即使在这之后,它也不会给设备供电,失败,并且大多数时候与计算机断开连接,导致程序员软件偶尔崩溃。我甚至尝试通过创建者IDE编程,同样的事情也会发生。 我的下一个尝试尝试复位编程模式和具有该装置的外部动力,我有一点成功。偶尔的自动检测,并将擦除设备尝试程序的Flash,但每次其次是这个失败的消息: 失败!SWD响应包包含失败状态! 有人知道发生了什么事吗?我试着联系威廉希尔官方网站 支持通过电子邮件和电话,他们只是反应太慢。接下来我将尝试用JTAG进行编程。 啊,还有一件事。我回到了PSoC 1器件,我知道可以用miniprog1编程程序,试图用miniprog3时,声称能够这样做,我得到同样的断开或是失败的程序问题,认为它只可能是一个糟糕的程序员,我买了一个又一个,但我的问题依然存在。请帮助! 以上来自于百度翻译 以下为原文 Hello everyone! I am trying to use the MiniProg3 to program my PSoC3, CY8C3245PVI-134. I have the programmer settings set to 5-pin SWD programming at 3.3V, Auto-Dectection on, and Power cycle mode with a clock speed of 1.6MHz. My programmer software is the most recent version. I have had nothing but problems. First off, when told to program the chip, the Auto-detect doesn't work so I have to manually set the device chip. Even after this, it never powers up the device, fails, and most times disconnects from the computer, causing the programmer software to occasionally crash. I've even tried programming through the Creator IDE, same thing happens. My next try was to attempt the Reset programming mode and having the device externally powered, I have a little more success with that. Occasionally the Auto-detect works, and it will erase the device and attempt to program the flash, but everytime it is followed by this Failure message: FAILED! SWD respond packet contains Failed status! Anyone have any idea what is going on? I've tried contacting Tech Support via both email and phone and they are just too slow to respond. I'm going to try to program with the JTAG next. Ah, one more thing. I went back to a PSoC 1 device that I know can be programmed with a MiniProg1, when attempting to program it with the MiniProg3, which claims to be able to do so, I get the same disconnection or just failure to program problems, thinking it just might be a bad programmer I bought another one, but all my problems persist. Please help! |
现在,我已经尝试使用JTAG用10针连接器和SWD编程5个和10个PIN连接器。以下是我从以下两个方面得到的失败:
JTAG:失败了!SPC轮询超时。与芯片失去通信(状态=0x80) SWD:失败了!SWD响应包包含失败状态! 有人能告诉我发生了什么事吗?软件中有什么东西我遗漏了吗?我不知道创建者中的某些组件? 以上来自于百度翻译 以下为原文 Well, I have now tried programming this PSoC3 using JTAG with the 10-pin connector and SWD with both 5 and 10-pin connectors. These are the following failures I get from both: JTAG: FAILED! Timeout of SPC polling. Lost communication with chip (Status = 0x80) SWD: FAILED! SWD respond packet contains Failed status! Can someone please tell me what's going on? Is there something in software I'm missing? Some component in Creator that I am not aware of? |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 12:10 , Processed in 0.713411 second(s), Total 44, Slave 39 queries .
