你好在一起,
昨天我将ST-LINK模块与STM8s发现的STM8S105C6T6模块分开了。之后我测量了功耗,不幸的是它远高于预期。在5V的电压水平下,它消耗66mA,在主动停止模式下仍然是40mA。你有没有人对其他消费价值观有不同的体验? 提前致谢 #STM8S发现功耗 以上来自于谷歌翻译 以下为原文 Hello together, yesterday I separated the ST-LINK module from the STM8S105C6T6 module of my STM8s discovery. Afterwards I measured the power consumption and unfortunately it was much higher than expected. At a voltage level of 5V it consume 66mA and in active halt mode still 40mA. Has anybody of you made some different experience with other consumption values? Thanks in advance #stm8s-discovery-power-consumption |
谢谢你的快速回答!
我断开了电源以外的一切。我在电源和VDD之间放了一个万用表。您是否测量过STM8s发现的当前状态? 干杯 克劳斯 以上来自于谷歌翻译 以下为原文 Thanks for your quick answer! I've disconnected everything besides the power supply. I put a multimeter between my power source and the VDD. Have you measured the current of your STM8s discovery? Cheers Klaus |
2877 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3710 浏览 6 评论
6124 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-23 18:53 , Processed in 1.180382 second(s), Total 75, Slave 59 queries .
