我试图为我的PIC32MZ1024EFF100做一个UART引导加载程序。如果我从HARMony引导加载程序示例开始,为了让该示例在我的设备上工作超过简单的引脚设置,我需要做哪些更改?谢谢
以上来自于百度翻译 以下为原文 I'm trying to make a UART bootloader for my PIC32MZ1024EFF100. If I start with the Harmony bootloader example, what changes will I have to make in order for the example to work on my device past the simple pin settings? Thanks |
谢谢你的快速回复。如果我想使用USB设备引导加载程序,那么我需要做些什么改变呢?我试着使用USB设备引导加载器,并且我遇到了使用引导加载器与应用程序在中断模式下使用Harmony USART驱动程序的问题。对于这个引导加载程序,我只是修改了PIN设置。
以上来自于百度翻译 以下为原文 Thank you for the quick reply. If I wanted to use the USB Device bootloader instead, what changes would I have to make? I tried using the USB device bootloader and I ran into issues using the bootloader with an application that had the Harmony USART driver in interrupt mode. For this bootloader, I just changed the pin settings. |
对于USB,如果连接与复制的BSP相同,那么应该可以正常工作。从简单的Bootload应用程序开始。
以上来自于百度翻译 以下为原文 For USB, if you are connected the same as the BSP you copied it should just work. Start with a simple Application to Bootload. There are issue with more complaceted ones. |
5145 浏览 9 评论
1993 浏览 8 评论
1921 浏览 10 评论
3162 浏览 3 评论
2218 浏览 5 评论
713浏览 1评论
601浏览 1评论
484浏览 1评论
613浏览 0评论
511浏览 0评论
GMT+8, 2024-11-10 22:53 , Processed in 0.903307 second(s), Total 47, Slave 42 queries .
