所附项目使用DMA实现Delta Sigma ADC的输出数据缓冲。
由于辐条宽度对于ADC等外围设备来说是16位的,所以我们需要两个独立的DMA来缓冲输出数据存储位置。ADC的输入通道选择是使用模拟MUX来完成的,它的选择线是由状态机驱动的。一旦当前ADC转换结束,模拟多路复用器的信道选择线将改变以连接下一个ADC的信道。 所附项目同时在PSoC 3和PSoC 5中工作。唯一不同的是PSoC 3在将ADC数据传送到存储器之前需要Endiad交换。 Delsig16Chhanel-20BIT-DMA-000 0.CyWrk.CaseV01.Zip 2.4兆字节 以上来自于百度翻译 以下为原文 The attached project implements Delta Sigma ADC's output data buffering using the DMA. Since the spoke width is of 16-bits for the peripherals like ADC, we need two independent DMAs to buffer the output data in a memory location. The ADC's input channel selection is done using an Analog Mux whose select lines are driven by a state-machine. Once the current ADC conversion is over, Analog Mux's channel select lines will change to connect the next ADC's channel. The attached project works in both PSoC 3 and PSoC 5 as well. Only difference is that PSoC 3 requires endian swapping before transferring the ADC data to memory. |
您可能在3之前使用创建者版本。上传的项目文件在创建者3下运行无错误。
鲍勃 以上来自于百度翻译 以下为原文 You are probably using a Creator version before 3.0. The uploaded project-file works error-free under Creator 3.0 Bob |
谢谢Senthilnathan。Bob Marlowe还给了我们他的项目:APP=论坛和RID=66562,现在我们可以选择和比较。遗憾的是,PSOC4中没有DMA((
以上来自于百度翻译 以下为原文 Thank Senthilnathan. Bob Marlowe also gave us his project: http://www.cypress.com/?app=forum&rID=66562 Now we can choose and compare. It is a pity that no DMA in PSoC4 ((( |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 15:37 , Processed in 1.024770 second(s), Total 76, Slave 60 queries .
