你好:
有没有人知道PSOC 4的中断延迟是什么?我运行一个4200与外部48兆赫时钟。当Itrigger与一个定时器进行中断比较时,在ISR切换输出线之前有一个800毫秒的延迟。IAM使用寄存器写,而不是生成函数之一。我的理解是,M0的潜伏期是16个周期,如果是这样的话,延迟大约只有350nS。我是不是有什么不对,或者是在这个MCU上中断得很慢? 数据表和威廉希尔官方网站 参考手册的搜索没有透露任何答案。 谢谢, 史蒂芬 以上来自于百度翻译 以下为原文 Hello: Does anyone know what the interrupt latency is for the PSoC 4? I am running a 4200 with an external 48MHz clock. When I trigger an interrupt with a timer compare, there is an 800ns delay before the ISR toggles an output line. I am using a register write, not one of the generated functions. My understanding was that latency for M0 was 16 cycles. If that was the case, the delay would only be about 350ns. Am I doing something wrong, or are interrupts slow on this MCU? A search of the data sheet and technical reference manual did not reveal any answers. Thanks, Stephen |
除了明显的,你有最高优先级的中断优先级,
我看到了这个手臂手册,附上。 问候,Dana。 PSoC 4中断延迟 168.4 K 以上来自于百度翻译 以下为原文 Other than the obvious, eg. you have the interrupt priority at highest, I saw this in ARM manual, attached. Regards, Dana.
嗨,Asha,
非常感谢你提供的信息。IDO有一个问题:我能理解为什么在RAM中放置ISR会影响中断的性能,但是为什么像ISRSListSo()这样的函数也需要放在那里呢? 谢谢, 史蒂芬 以上来自于百度翻译 以下为原文 Hi Asha, Thanks very much for the information. I do have one question: I can understand why placing the ISR in RAM would affect the performance of interrupts, but why do functions like isr_Start() need to be placed there as well? Thanks, Stephen |
767个成员聚集在这个小组
加入小组2208 浏览 1 评论
1960 浏览 1 评论
3785 浏览 1 评论
1871 浏览 6 评论
1615 浏览 1 评论
1567浏览 2评论
701浏览 2评论
528浏览 2评论
507浏览 2评论
1392浏览 2评论
GMT+8, 2025-4-29 08:37 , Processed in 1.571192 second(s), Total 77, Slave 61 queries .
