我在N5162A信号发生器中加载了几个文件,并希望在每个波形的开头和结尾添加标记。
我似乎无法在文档中找到允许我读取文件大小的参考,因此我可以将标记放在文件的末尾。 知道如何读取文件大小以确定最后一个标记的放置位置吗? 以上来自于谷歌翻译 以下为原文 I have several files loaded in the N5162A signal generator and want to add markers at the start and end of each waveform. I cannot seem to find a reference in the documentation that allows me to read the file size so I can place the marker at the end of the file. Any idea how I could read a file size to determine where to place the last marker? |
Hi -The MXG将在Marker Utilities屏幕中显示易失性存储器中所有波形的长度。按键顺序:Mode-> Dual ARB-> More(2 of 2) - > Marker Utilities-> Set Markers然后你可以设置Marker 1 on
第一点,最后一点是Marker 2。 要设置为最后一个点,请选择“点范围”上的“设置标记”,然后为“第一个点”和“最后一个点”输入相同的值到文件的点数。 设置标记时,它会自动保存到易失性存储器中的波形文件中。 要使用新标记设置永久保存文件,请将波形存储在非易失性存储器中。按键顺序:模式 - >双ARB->选择波形 - >波形段 - >存储 - >存储段到内部存储器 - 以上来自于谷歌翻译 以下为原文 Hi - The MXG will display the length of all waveforms in volatile memory in the Marker Utilities screen. Key sequence: Mode->Dual ARB->More (2 of 2)->Marker Utilities->Set Markers Then you can set Marker 1 on the first point, and Marker 2 on the last point. To set to the last point, you select Set Marker on Range of Points, then enter the same value for the First Point and Last Point to number of points of the file. When you set the marker, it is automatically saved to the waveform file in the volatile memory. To permanently save the file with the new marker settings, store the waveform in nonvolatile memory. Key sequence: Mode->Dual ARB->Select Waveform->Waveform Segments->Store->Store Segment to Internal Memory Regards - |
1201 浏览 0 评论
2338 浏览 1 评论
2139 浏览 1 评论
2012 浏览 5 评论
2887 浏览 3 评论
937浏览 1评论
687浏览 0评论
789浏览 0评论
1202浏览 0评论
GMT+8, 2024-11-11 00:11 , Processed in 0.998701 second(s), Total 44, Slave 39 queries .
