我试图找出ICSP是否有通用的布局。我在DIP包里有PIC12F675和PIC10F200 8引脚IC。我看了引脚说明,看起来我必须制作两个独立的PCBS来编程,除非有一个通用板,它们可以同时安装在和b上。可以编程。
以上来自于百度翻译 以下为原文 I am trying to find out if there is a universal layout for the ICSP. I have PIC12F675 and PIC10F200 8 pin IC's in the DIP package. I looked at the pin descriptions and it looks like I would have to make 2 separate PCBS for programming, unless there is a universal board that they can both fit on and both be programmed on. |
3个回答
PIC10是一个6引脚PIC,所以它的8引脚DIP ValANSAS具有2个引脚为NC PIC12的不同布局是一个8位PIC。它具有与14位和20位PIC16S/PIC18S相同的布局,只有极少数例外。
以上来自于百度翻译 以下为原文 PIC10 is a 6-pin PIC, so its 8-pin DIP variant has a different layout with 2 pins being NC. PIC12 is an 8-bit PIC. It has the same layout as 14-bit and 20-bit PIC16s/PIC18s with very few exceptions. |
你的意思是:PIC12是一个8针PIC。它具有与14引脚和20引脚PIC16S/PIC18S相同的布局,只有极少数例外。
以上来自于百度翻译 以下为原文 You mean: PIC12 is an 8-pin PIC. It has the same layout as 14-pin and 20-pin PIC16s/PIC18s with very few exceptions. |
5323 浏览 9 评论
2076 浏览 8 评论
1982 浏览 10 评论
3254 浏览 3 评论
2293 浏览 5 评论
835浏览 1评论
732浏览 1评论
674浏览 1评论
728浏览 0评论
622浏览 0评论
GMT+8, 2025-2-3 19:34 , Processed in 0.930964 second(s), Total 46, Slave 41 queries .
