晚上好,我想用一个由我的dsPIC33EP256MC502的四个PWM输出驱动的H桥电路控制一个扬声器。在数据表中,我读到有一个FLT引脚,用来告诉PIC出问题了,例如H桥的一条腿缩短了。找不到任何一个原理图来产生这个信号。我的意思是,如何在H桥电路中产生一个感应过电流的信号?有标准的原理图吗?谢谢您。
以上来自于百度翻译 以下为原文 Good evening, I want to control a speaker with an H-bridge circuit driven by four PWM outputs of my dsPIC33EP256MC502. In the datasheet I read that there is the FLT pin that is used to tell the PIC that something goes wrong, for example a leg of the H bridge is shorted. I read about this pin but I can't find anywhere any piece of schematic to generate this signal. I mean, how can I create a signal that senses an overcurrent in a H bridge circuit? Are there standard schematics? Thank you. |
在H桥的低侧上的电流感测电阻器,加上比较器将做TE。HTTP:/WW1.MICCHIP.COM/DeLoSs/En/DeVICEDCO/41233 A.PDFPAGE 21示出了通过ADC的电流信号探路者的方案。用适当尺寸的比较器电路来复制运算放大器将传送一个数字信号送到FLT。
以上来自于百度翻译 以下为原文 A current sense resistor at the low side of the H-bridge, plus a comparator would do te trick. http://ww1.microchip.com/downloads/en/DeviceDoc/41233A.pdf page 21 shows a scheme to read the current signal by ADC. replaing the opamp with a - properly dimensioned - comparator circuit would deliver a digital signal to be fed to FLT. |
5383 浏览 9 评论
2107 浏览 8 评论
2009 浏览 10 评论
3285 浏览 3 评论
2319 浏览 5 评论
889浏览 1评论
778浏览 1评论
714浏览 1评论
773浏览 0评论
664浏览 0评论
GMT+8, 2025-3-10 10:01 , Processed in 1.420984 second(s), Total 76, Slave 60 queries .
