大家好,
我的链接器有问题,我不知道如何解决它。有人可以帮忙吗?我是新手。 运行链接器 clnk -l''C: Program Files(x86) STMicroelectronics STM8S_StdPeriph_Lib_V2.0.0 Libraries STM8S_StdPeriph_Driver src''-debug stm8s103.sm8 -l''.. .. .. .. .. .. program files cosmic cxstm8_16k lib''-l''.. .. .. .. .. .. program files(x86) cosmic cxstm8_16k lib'' - mdebug stm8s103.map debug stm8s103.lkf 命令:''clnk -l''C: Program Files(x86) STMicroelectronics STM8S_StdPeriph_Lib_V2.0.0 Libraries STM8S_StdPeriph_Driver src''-debug stm8s103.sm8 -l''.. .. 。 。 .. .. program files cosmic cxstm8_16k lib''-l''.. .. .. .. .. .. program files(x86) cosmic cxstm8_16k lib'' - mdebug stm8s103.map debug stm8s103.lkf''失败,返回值为:1 退出代码= 1。 stm8s103.elf - 2个错误,0个警告 #大小溢出 以上来自于谷歌翻译 以下为原文 Hi Everybody, I have some problem with my linker, and I don't know how to fix it. Can somebody help?? I'm new to this. Running Linker clnk -l''C:Program Files (x86)STMicroelectronicsSTM8S_StdPeriph_Lib_V2.0.0LibrariesSTM8S_StdPeriph_Driversrc'' -o debugstm8s103.sm8 -l''..........program filescosmiccxstm8_16klib'' -l''............program files (x86)cosmiccxstm8_16klib'' -mdebugstm8s103.map debugstm8s103.lkf The command: ''clnk -l''C:Program Files (x86)STMicroelectronicsSTM8S_StdPeriph_Lib_V2.0.0LibrariesSTM8S_StdPeriph_Driversrc'' -o debugstm8s103.sm8 -l''..........program filescosmiccxstm8_16klib'' -l''............program files (x86)cosmiccxstm8_16klib'' -mdebugstm8s103.map debugstm8s103.lkf '' has failed, the returned value is: 1 exit code=1. stm8s103.elf - 2 error(s), 0 warning(s) #size-overflow |
3个回答
我遇到了同样的问题。你究竟做了什么来纠正它。
以上来自于谷歌翻译 以下为原文 I'm having the same problem. What exactly did you do to correct it. |
阅读我的消息,问题是宇宙编译器
[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM8Discovery/Cosmic或更糟糕的compilatorlinker编程& FolderCTID = 0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1& TopicsView = https:// my .st.com / public / STe2ecommunities / mcu / Lists / STM8Discovery / AllItems.aspx& currentviews = 0] https://my.st.com/public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=% 2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fSTM8Discovery%2fCosmic%20or%第二十条%20worse%20compilatorlinker%20ever%20programmed&安培; FolderCTID = 0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1&安培; TopicsView = HTTPS%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists% 2FSTM8Discovery%2FAllItems%2Easpx&安培; currentviews = 0 以上来自于谷歌翻译 以下为原文 Read my message, the problem is cosmic compiler [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM8Discovery/Cosmic or the worse compilatorlinker ever programmed&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM8Discovery/AllItems.aspx¤tviews=0] https://my.st.com/public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fSTM8Discovery%2fCosmic%20or%20the%20worse%20compilatorlinker%20ever%20programmed&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM8Discovery%2FAllItems%2Easpx¤tviews=0 |
2865 浏览 1 评论
3279 浏览 1 评论
1859 浏览 1 评论
3706 浏览 6 评论
6116 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
405浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
501浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
329浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
243浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
349浏览 2评论
GMT+8, 2025-2-19 08:56 , Processed in 1.202758 second(s), Total 81, Slave 65 queries .
