扫一扫,分享给好友
您好!
我使用最新的PSOC Creator与CY8C5868 Lti-LP039。当我尝试编译一个程序时,我总是会得到这两个错误: 组件错误:CysBooT。Cyb BooToV310组件(CythBooD)是一个过时的组件。它不再被推荐使用,应该用组件的生产版本(或者替代的实现)来代替。 CysFIT因错误而中止,请处理所有错误并重新运行CysFIT。 如何解决这个问题? 当做 马萨布 以上来自于百度翻译 以下为原文 Hi I'm using the latest PSOC Creator with CY8C5868LTI-LP039. When I try compiling a program I keep getting these two errors: Error in component: cy_boot. The cy_boot_v3_10 component (cy_boot) is an Obsolete component. It is no longer recommended for use and should be replaced with a production version of the component (or an alternative implementation). CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. How to fix this? Regards Masab |
4个回答
看一下这个页面,它显示了
从PSoC Creator 2.1开始,引导装载系统已经被重新组织以提供更多的配置选项。在以前的版本中,Bootloader系统是CysBooT组件的一部分(在所有设计中都是自动和不可见地实例化的一个必需组件)。从PSoC创建者2.1开始,Bootloader组件与CysBooT组件分离,并且作为组件目录中的单独组件可用。请参考CoupDoDROWDOWN ID“= GPLITAY1”风格=“文本修饰:下划线”HReF=“/”?在系统引用指南(Advand & Gt;文档和GT;系统引用)中,RID=57561π>第11章Bootloader迁移,以了解如何将旧版本的引导加载程序/可引导加载项目迁移到PSoC Creator 2.1。 在创建者文档化下的系统参考指南似乎是答案。 问候,Dana。 以上来自于百度翻译 以下为原文 Take a look at this - www.cypress.com/ and on this page it shows - Beginning with PSoC Creator 2.1, the bootloader system has been reorganized to provide more configuration options. In previous releases, the bootloader system was part of the cy_boot component (a required component that is automatically and invisibly instantiated in all designs). From PSoC Creator 2.1 onwards the bootloader component is separated from cy_boot component and is available as a separate component in component catalogue. Please refer by CouponDropDown" id="_GPLITA_1" style="text-decoration:underline" href="//www.obk20.com/bbs/?rID=57561#">Chapter11.Bootloader Migration’ in System Reference Guide (Help>Documentation>System Reference) to know how to migrate your older versions of bootloader/bootloadable projects to PSoC Creator 2.1. System Reference Guide under Creator documenation seems to be answer. Regards, Dana. |
好的,谢谢。
当我手动下载CythBooE的更新版本时,问题就解决了。 此外,手头的问题只针对PSOC5LP项目。 以上来自于百度翻译 以下为原文 ok Thank You The issue was solved when i manually downloaded the updated version of cy_boot. Also, the problem at hand was only for PSOC5 LP projects |
我似乎也有类似的问题。我不明白这个解决办法。
我有一个新的CY8CKITR 050 PSoC 5LP套件,我试过一个例子。 这个例子来自CD上的工具箱。我不知道哪里可以找到隐形的靴子 组件。请帮忙。 以上来自于百度翻译 以下为原文 I seem to be having a similar problem. I don't understand the solution. I have the new CY8CKITR-050 PSOC 5LP kit and I tried an example. The example came with the kit on the CD. I don't know where to find the invisible Cy_boot component. Please help. |
您可以通过右键单击“WrkStaseExplorer”窗口中的工作区名称并选择“更新组件”来更新Bootloader组件(以及PSoC Creator中所有组件的旧版本)。(或选择Projt≫Update组件)选择组件的最新版本点击“下一步”并说“完成”。这将更新您的设计中的所有组件到最新版本。
以上来自于百度翻译 以下为原文 You can update the bootloader component (and all the older version of the components in PSoC Creator) by right-clicking on the workspace name in the "Wrokspace Explorer" window and selecting "update components".(Or select Project > Update Components) Select the latest version of components after clicking "Next" and say finish. This will update all the components in your design to latest versions. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
274浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 19:46 , Processed in 0.727826 second(s), Total 50, Slave 45 queries .
