目前,我正在使用PIC 18LF45 50,它与正在运行XP的笔记本电脑通信。我正在从Windows XP升级到Windows 10 OS,现在运行PIC 8LF4550的USB设备不再与Windows 10 OS通信。我试着在Microchip网站上寻找司机,但我没有找到任何运气。有什么想法我能得到支持Windows 10操作系统的PIC8LF45驱动程序?谢谢您,
以上来自于百度翻译 以下为原文 Currently, I am using PIC 18LF4550 that communicates with notebook PC which is running XP. I'm in process to upgrade to Windows 10 OS from Windows XP and now my USB device that runs the PIC 8LF4550 is no longer communicating with Windows 10 OS. I tried to look for the driver on MicroChip's website but I am not finding any luck. Any idea where I can get the PIC 8LF4550 driver that supports Windows 10 OS? Thank you, |
3个回答
HID类的好处是驱动程序内置在操作系统中。您对这两台机器都使用相同的可执行文件吗?建议在WI10机上进行改造。如果您的应用以MLA中的示例开始,则系统调用链接都公开在代码中,而不是隐藏在单独的DLL中。代码位于“开始/结束剪切和粘贴块”注释中。
以上来自于百度翻译 以下为原文 The nice thing about HID class is the drivers are built into the operating system. Are you using the same executable for both machines? Suggest rebuilding on the Win10 machine. If your appllication started with an example in the MLA, the system call links are all exposed in the code rather than hidden in a separate DLL. The code is within "BEGIN/END CUT AND PASTE BLOCK" comments. |
我有类似的问题,与上一版本的MLA USB堆栈HID类设备(PIC18F14K50),出色的工作与我的Windows 7(64位)计算机与我自己的32位软件,但在一些新的PC与Windows 10不工作。但我看到它与Wi10无关,我把它安装在我的旧笔记本电脑上(Win 10 64位)在戴尔纬线E6400上,所有的工作都很好。我没有自己的现代电脑来调查这个问题。
以上来自于百度翻译 以下为原文 I have the similar problem, with last verson MLA USB Stack HID class device (PIC18F14K50) that excellent works with my Windows 7 (64 bit) computer with my own 32bit software but on some new PC witn Windows 10 not works. But as I see it not related to Win10, I install it on my old laptop (Win 10 64 bit) on Dell Latitude E6400 and all works good. I haven't my own modern PC for investigation this problem. |
5318 浏览 9 评论
2073 浏览 8 评论
1978 浏览 10 评论
3250 浏览 3 评论
2286 浏览 5 评论
831浏览 1评论
724浏览 1评论
670浏览 1评论
723浏览 0评论
619浏览 0评论
GMT+8, 2025-2-1 10:01 , Processed in 1.265287 second(s), Total 81, Slave 65 queries .
