在我的设计中;
PCB总层数:4 天线层:第2层 要组装的组件仅在第四层中。 真实和理论上的结果是不匹配的。 我想增加天线的电感值,但相反,值也在减小。 是什么原因?谢谢你的帮助。 ANTENNA 1结果: -THEORY INDUCTANCE VALUE:1.84 uH -REAL INDUCTANCE VALUE:3.3 uH 天线2结果: -THEORY INDUCTANCE VALUE:6.62 uH -REAL INDUCTANCE VALUE:0.7 uH #天线设计 以上来自于谷歌翻译 以下为原文 In my design; pcb total layer : 4 Antenna layer : 2nd The components to be assembled are only in the fourth layer. Real and theoric results are don't match. I want increase inductance value of antenna, but on the contrary, the value is decreasing too. What is reason ? thank you for yours help. ANTENNA 1 RESULTS: -THEORY INDUCTANCE VALUE : 1.84 uH -REAL INDUCTANCE VALUE : 3.3 uH ANTENNA 2 RESULTS: -THEORY INDUCTANCE VALUE : 6.62 uH -REAL INDUCTANCE VALUE : 0.7 uH #antenna-design |
你好Ufuk,
我们使用RF模拟软件确认设计1和2的理论值。根据我们的经验,我们相信天线的电感测量应该非常接近。 模拟和原型之间差异的两种可能的解释是,第一次是环路匝之间的短路,第二是PCB上天线的实施问题:如果由于某种原因某些铜区域覆盖环形天线,磁通量会被阻塞测得的电感远低于预期。 如果您打算使用ST产品(Mifare不是STMicroelectronics产品品牌),我们可以进一步分析您的PCB布局。 最好的祝福, NFC硬件支持2 以上来自于谷歌翻译 以下为原文 Hello Ufuk, we do confirm the theoretical values for design 1 and 2 using an RF simulation software. Based on our experience, we are confident that antenna a inductance measurements should be very close. Two possible explanation of a difference between simulation and prototype are, first short cuts between turns of the loops, second an implemantation issue of the antenna on the PCB: if for any reason some area of copper covers the loop antenna, magnetic flux is blocked resulting in a measured inductance much lower than expected. If you are planning to use an ST product (Mifare is not an STMicroelectronics product brand), we could go further into the analysis of your pcb layout. best regards, NFC Hardware support 2 |
谢谢你的解释。我想改进现有的天线。 pcb是天线在同一区域。我还使用M24LRE设计了另一台pcb。我订购了样品,我会试试。
以上来自于谷歌翻译 以下为原文 Thank you for yours explanation. I want to improve the current antenna. Antennas are in the same region both pcb's. Also I've designed another pcb using M24LRE. I ordered the sample and I will try it. |
2896 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
342浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-6 02:06 , Processed in 1.117556 second(s), Total 79, Slave 63 queries .
