扫一扫,分享给好友
在我看来,当设置IF BW低于300Hz时,Data Link软件会将IF BW更改为300 Hz或由于超时而无法连接。
解决方法是:先保存扫描,然后使用数据链接加载文件。 通过这样做,您会发现数据链路将IF BW固定为300 Hz,即使记录扫描的实际IF BW较低。 我怀疑数据链路可能是针对N9923A使用较旧的固件而最低的IF BW为300 Hz。 有关此信息和未来数据链接更新的任何线索可能会对此进行调整吗?编辑:tim于2013年4月3日下午1:02 以上来自于谷歌翻译 以下为原文 It appears to me that when set IF BW lower than 300Hz, Data Link software would either change the IF BW to 300 Hz or fail to connect due to time-out. The go around is: save the sweep first then use the Data Link to load the file. By doing so you will find Data Link will fix the IF BW to 300 Hz even the actual IF BW of the recorded sweep is lower. I suspect Data Link may have been made for N9923A with older firmware and the lowest IF BW was 300 Hz. Any clue on this and a future Data Link update may get this adjusted? Edited by: Tim on Apr 3, 2013 1:02 PM |
1330 浏览 0 评论
2396 浏览 1 评论
2215 浏览 1 评论
2084 浏览 5 评论
2972 浏览 3 评论
1226浏览 1评论
781浏览 0评论
1026浏览 0评论
1332浏览 0评论
GMT+8, 2025-1-12 15:39 , Processed in 1.251127 second(s), Total 76, Slave 60 queries .
